Air Shocks
Old Dec 19, 2017 | 09:23 PM
Mishawaka's Avatar
Mishawaka
Default Air Shocks
Anyone ever do air shocks on all four corners? I have this idea that then it could be raised or lowered depending the road conditions or for aesthetics.
Old Dec 19, 2017 | 09:33 PM
PatternDayTrader's Avatar
PatternDayTrader
My vote is you put that idea right out of your mind.
Old Dec 19, 2017 | 09:45 PM
81c3's Avatar
81c3
You go boy!!
Old Dec 20, 2017 | 12:05 AM
gerardvg's Avatar
gerardvg
Camber and toe in will change as you change ride heights, excessive tire wear will result...
Old Dec 20, 2017 | 01:48 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Thank you for explaining why It was a reasonable question. I've driven over 100K in my C4 at the stock suspension heights. Frankly if there was a way to easily lower the suspension 2 inches when the roads permit or at a show it would be something to consider.
Old Dec 20, 2017 | 07:41 AM
Cjunkie's Avatar
Cjunkie
Maybe on a C1 with slotted mags?
Old Dec 20, 2017 | 07:47 AM
MatthewMiller's Avatar
MatthewMiller
I'd be less worried about alignment changes and more worried about the spring rates you create with air shocks. Keep in mind that air shocks aren't dampers that work on air, they are normal hydraulic dampers that have air springs added inside. When you raise the ride height at one end, you're adding preload to those air springs and removing preload from the stock leaf springs (or coil springs in many other cars). The potential problem is that the leaf springs are linear rate: no matter where the wheels are in their range of suspension travel, the spring rate remains the same. OTOH, air springs are progressive, and with a high rate of progression (every time their volume halves, the spring rate doubles). You end up with spring rates varying all over the map as the suspension moves around during normal driving. The result is non-linear handling.
To Air Shocks
