Grease points
Dec 20, 2017 | 02:55 PM
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Grease points
How many grease points are there on a 93 Corvette?
Dec 20, 2017 | 02:59 PM
Depends on how many suspension and steering components have been replaced. If the answer to that question is zero, then I'm pretty sure only the ball joints were greasable. So four grease fittings.
Dec 20, 2017 | 04:18 PM
Dec 20, 2017 | 05:32 PM
Quote:
Originally Posted by
mickey5
Tie Rod ends?
I'm pretty sure the original tie rod ends are sealed.
Dec 20, 2017 | 07:12 PM
I am confident that all of my suspension parts are factory originals and there are 4 grease fittings, one for each ball joint. That is all.
Aftermarket tie rod ends usually have a grease fitting but not the originals. Strange but true.
1995 base coupe
Dec 20, 2017 | 11:36 PM
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
there are 6 on my original 85
Dec 21, 2017 | 08:37 AM
Thank you guys. Just found the four originals.
Dec 21, 2017 | 02:00 PM
6
Cruisinfanatic
yes on the 1985, just serviced the front end locations
Dec 27, 2017 | 10:03 PM
70ZZ3 96LT4
Actually there are 8 fittings on early C4. 6 front and 2 back
Dec 27, 2017 | 10:31 PM
Cruisinfanatic
That's correct for the '85 and some other years! One of those things that ain't so difficult to count and visually check when servicing.
If less than OE spec u-joints are used for service it could change the count to as high as 14,
