headlight trouble
Old Oct 10, 2002 | 08:27 PM
DADDY D's Avatar
DADDY D
Default headlight trouble
My father has a 90 vette. when you turn the headlights they start to turn slowly and then stop and creep open sometimes they hang and then open or when closing they close half way and stop you can flip the switch and they will go down but sometime they will go all the way down but the motor will still be running what is going on here and what to do to fix it
Old Oct 10, 2002 | 08:34 PM
vette92_1's Avatar
vette92_1
Default Re: headlight trouble (DADDY D)
Read this thread. It's a fairly easy fix if you have any mechanical ability at all.
http://forums.corvetteforum.com/zerothread?id=402866
Old Oct 10, 2002 | 08:39 PM
DADDY D's Avatar
DADDY D
Default Re: headlight trouble (vette92_1)
how do i get to the gears and bushing
Old Oct 10, 2002 | 08:57 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
You probaly, most likely, only need the bushings. MAD or Ecklers has them for around $4.99 a side.
Your 90 should be easy to do. Remove the theadlight assy from the car. There are about seven bolts holding it in. There is one tricky one on the upper inside that is hidden behind a clamp. Also disconnect the two wire connectors
Once you have the assy out, look at the motor! It connects to a large round housing which is the gear and your targrt, the bushings!
Three screws secure the round cover to the round housing. Be carefull and remove these three screws. When you remove the cover, use a razor blade to carefully separate the gasket from the housing and lift off the round cover
You will see the large drive gear and a bunch of crap
Carefully pry the large gear up and out. Clean the junk out. Turn the large gear over to expose the metal side and you will see where the three bushings go
Reinstall, (pressing in) the large gear with the new bushings and reinstall the cover and then reinstall the assy. reconnect the 2 wires and VOILA!
The first light might take you an hour or two, but the second light will be less than an hour
Jack
To headlight trouble
