antenna broke? :(
Old Oct 10, 2002 | 10:11 PM
Izover4u's Avatar
Izover4u
Default antenna broke? :(
I think my antenna kick the bucket... I installed a new headunit and it was working fine for awhile and since yesterday when i turned my radio on nothing happens... I dont even hear the motor running or anything... its just dead...Is there a way to test it or fix it? or do i have to buy a whole new unit? if so from where? :cheers:
[Modified by Izover4u, 8:31 PM 10/10/2002]
Old Oct 11, 2002 | 12:44 PM
detto's Avatar
detto
Default Re: antenna broke? :( (Izover4u)
Check if you have juice in the leads comming to the antenna motor.
If the motor is dead I guess you will have to replace the whole unit,
think it is about 80$.
Check this link think http://www.tld-corvette.com/catalog.htm :seeya
Old Oct 11, 2002 | 02:37 PM
Steel Blue 91's Avatar
Steel Blue 91
Will the radio play when you turn it on? CD? Start simple and check the fuses.
Old Oct 11, 2002 | 06:05 PM
Izover4u's Avatar
Izover4u
Default Re: antenna broke? :( (Steel Blue 91)
radio plays (lots of static) but the antenna does not go up? :confused:
Old Oct 12, 2002 | 03:47 AM
92TripleBlack's Avatar
92TripleBlack
First listen for the relay to click inside the rear of the car. This will click when you turn on the radio. Its the antenna relay. If it isn't clicking, you have either a bad relay or more likely a blown fuse or bad connection on your radio to the antenna wire. If it does click, test the wires on the other side and check fuses also. If it is getting power, you probably need a new one.
Old Oct 14, 2002 | 06:51 PM
Izover4u's Avatar
Izover4u
Default Re: antenna broke? :( (92TripleBlack)
thanx triple.. im goin to take a look at it this weekend right now i have midterms :(... Thanks guys
To antenna broke? :(
