Head Trouble on My Son's '90 C4
I have a 1990 C4 with the L98 engine. It has a blown head gasket. Around here it is just as cheap to have the engine swapped as it is to have the heads pulled. I have access to a 1988 Camaro with the Tuned Port 5.0 engine. Would this be a bolt in swap other than the accessories on the front ? I'm just weighing my options. The car is a daily driver so it doesn't have to be a monster. Any advice would be appreciated
Considering it's a smaller displacement engine (305 ci) I can't see how the computer would work. So that means a computer swap. That in turn means no support for the instrument cluster.
Pro Mechanic
While 305 comes with smaller injectors and I think the 305 would run "fine" with the 'Vette ECM, why down grade? No way in hell would I make that swap. I'd fix the problem on the 350...then run the wee out of it.
Due to the considerable loss in power and torque combined with the required ecm change/ tuning You would be better off with actually doing a head gasket replacement. Considering how open the engine bay is and the simplicity of a gen 1 small block you could do this in a day or two, not counting time of having your heads in the shop getting milled. For me to do it here in florida would run me as follows:
Head milling - $250 for the pair
Top end gasket set - $76
Head Bolts - $16
Mobile1 5Qt - $23
Oil filter of choice - $7
Coolant 50% - $48 ( 3 gal)
Total - $420 plus local tax
And your choice of service manual or youtube video.
The hardest part of this whole project will be setting valve lash and ensuring the distributor is placed in the right location.
Head Bolts - $16
Mobile1 5Qt - $23
When I read your post - I am reminded of the expression "There is No Replacement for Displacement."
I'd strongly recommend just repairing the 5.7 L motor you already have !!!
You should be able to pull both heads in less than 8 hours - and reinstall will take about the same amount of time.... I've pulled more than one motor out of a C4 - and I don't believe that you can do the job as quickly as you can pull the cylinder heads.
And BTW - while you have the heads out - consider doing a valve job - you may very well find that there are more than a couple of valve guides that are worn more than they should be... Might as well deal with it while you're there.....
There's way more issues '88 to '90 than have been mentioned here already. There's no way for anyone other than a very experienced C4 guy to pull this off.
It has to be way more realistic to repair what you've got unless "There's more to the story" that hasn't been passed on.
Before we turn this into a "Your wrong and here's why" thread and run him off lets get as much as we can from him.
Reason I could think of that it may be better to use the 305 is if the L98 has more potential damage than just a leaking head gasket, ie coolant in the oil, metal shavings in the oil. Something of this nature would lend me to think replace over rebuild. Also he my have a running 305 that is in good working order with reasonable miles. If this is the case the engine would be free he would just do well with a tune and all should work just fine. The trade off for going smaller is the lowered power means it will work harder leading to more fuel use and possibly an early demise to the engine.
Unfortunately we need to hear more from the OP to provide a grounded suggestion not a diehard "It has to be this way because I said so."
Zen Vet Master Level VII
w/ the above - fix what you have. blown head gaskets are somewhat of a common problem on the aluminum head L98, especially the right and left rear cylinders. if you're handy with the wrench, the repair, while somewhat of a PITA, it's still a SBC and a relatively doable fix. I can't believe it's cheaper to swap out the engine than replace head gaskets. besides, with swapping the engine, now you're injecting a whole new set of issues in the mix. not saying it can't be done - just my 2-cents.
What's it worth?
I'm considering selling this car before I spend any more money on it. What is it worth? It has 102,000 miles. Trans was rebuilt in September ( have receipt). I have the original window sticker and floor mats. It's dark smoke gray. Good tires, new mufflers.
Charcoal Mettalic is a rare color, but not enough to bring big value.
