Very poor gas mileage.
Or you can do it yourself by banging on the cats and listen for rattling.
If they rattle its time for new cat/s. 86 has pre-cats at each bank and one before the diff.
I would get a scanner on it and check the voltage swings, fuel trim numbers and see if it goes in to closed loop. If it is running open loop, that would radically affect mileage. I don’t think a tune up or plugs would cut the mileage more than in half.
1 timing double check the no 1 piston is at TDC when timing mark is at TDC, the outer ring on harmonic balancer can slip. retarded ignition will use more gas.
2 check TPS voltage should be 0.54 volts DC with ignition on or idling, i find 0.60 volts helps keep idle smoother.
3 600 rpm is what she should idle at, 580 i think is when hot higher when cold till she warms up. Should start run at 1200 rpm then drop to 600 rpm, if it doesn't check your EGR is not sticking open should spring closed. you may have to set the base idle if the idle screw has been adjusted by someone.
4 exhaust check for clogged cat or muffler.
5 does the torque converter lock, when going up hills do the rpm stay or go up then down when over the crest of a hill. Should only affect highway mileage.
6 does your transmission slip??????
7 Check your IAC valve has not come loose
Good luck
Personally, I have DataMaster for my laptop and a handheld scanner and I can read the information they give. If I see the O2 giving funny readings, car is staying in open loop, or always reading lean in general, then its telling me the sensor is compensating by richening up the mix. That means the sensor itself is probably bad. O2s generally do not throw codes until they are completely toast, which will explain why yours isnt setting that code.
I would then start with the standard tune up. Change plugs, wires, coil/cap/rotor, fuel filter, and then the O2 sensor.
Cat problems are possible, but it can be cause/effect. A bad O2 will richen up things so bad you clog the cats.
I always start with a basic tuneup.
