Wheels
Old Jan 4, 2018 | 10:54 PM
MikieG1971's Avatar
MikieG1971
Default Wheels
I am looking at puting ZR1 sized rims and tires on my 1996.
Where is a good place to look for wheels?
from what i see i will need
17"x 11" rim with 52mm offset
17"x 9.5"rim with 52mm offset
Any advise would be greatly appreciated.
Old Jan 4, 2018 | 11:19 PM
Moser28's Avatar
Moser28
OE Wheels is where I ordered mine for my 96. Mine are 56mm offset in the front (9.5 rim) and 50mm offset (11x17) in the back. They will also put tires on and balance them too. Should have mine next week. Also free shipping.
Old Jan 5, 2018 | 11:31 AM
turtle96's Avatar
turtle96
First, I will admit to not knowing exactly what is on my car, which I just inherited from my dad who only owned it a few months. It is a Collector Edition and it has some aftermarket wheels on it I have been trying to identify. I believe they are ZR1 sizes (the car has 315 tires on the rear and 275s in front) and I am fairly sure they came from OE Wheels. I don't know anything about the offsets, but OE Wheels sells wheel sets intended for the application, and they have a bunch of styles, so they should be able to fix you up. Good luck.
Old Jan 5, 2018 | 12:48 PM
MatthewMiller's Avatar
MatthewMiller
FWIW, I run 17x11 with 50mm offset at all four corners on my 96, and they fine with 315 tires. You're in the right range pf sizes and offsets. The 11" wheels up front make a difference in the way the car looks (for the better IMO), and allow full rotation. You can also run 18x11 and have a wider selection of tire brands and models to choose from.
ETA: Forgot to include the following. The actual ZR1 rears were 17x11, but with only 36mm offset, whereas the GS rears had the 50mm that I use. You want the GS 50mm offset, not the ZR1. The fronts for both cars were 9.5" with 56mm offset, just like Moser is using.
Old Jan 5, 2018 | 05:42 PM
Moser28's Avatar
Moser28
Those look like the ones I ordered from OE Wheels only in a different finish. They look fantastic with those 315's in the back!
Old Jan 5, 2018 | 05:53 PM
81c3's Avatar
81c3
315's only way to go!!
Old Jan 5, 2018 | 06:12 PM
c4cruiser's Avatar
c4cruiser
The '96 Grand Sport coupe used a 17x11 rear wheel with a 50mm offset. The front wheels on the GS were a 17x9.5 with a 56mm offset. All of the '89-'96 wheels in the 17"x9.5" size had a 56mm offset.
The 52mm offset you mentioned will work, but it might be worth the extra trouble to find the 5-spoke design wheels that have the OEM offset. Also make sure that the bolt circle is 5x4-3/4" or in Metric-speak: 5x120.6mm
Try eBay for AFS wheels. OE Wheels have a good reputation but either of these will be heavier than the OEM GS wheels.
Old Jan 6, 2018 | 04:39 PM
MikieG1971's Avatar
MikieG1971
I am not educated on wheels. What i know is i like the ZR1 appearance. The tire i have chosen is the Goodyear Eagle F1 GS-D3 which only comes in 17 inch (correct me if i have overlooked a supplier with other diameters).
So am i to understand that rims can be ordered with backspacing of your choice?
If so, it is my intent to get the right offset that tucks the 315 tire in as cleanly as possible. Now if there is a bit that peeks out, im fine, just dont want it looking like my cousins 73 Nova back un the day. After all, this a Corvette. We must at least act luke we have some class!
So with this in mind, the 275 in front can be standard offset, but the 315 out back without the widebody kit of the ZR1, what is the offset i need?
Old Jan 6, 2018 | 04:57 PM
MatthewMiller
It depends on the wheel and company you order from. But if you're ordering Corvette replicas, then you'll probably be limited to the backspacing choices that were actually installed as original equipment on various models.
For a "regular" 1996 C4 (i.e., not a GS or ZR1 and no flares or widebody kit of any kind):
  • If you go with 9.5" wheels in the front, you want 56mm offset for them.
  • For 17x11, either in back or at all four corners, you want 50mm offset.
They will be right. They will look great, stay just inside the fenders, and they won't rub anything. Here is my car on AFS replica A-Mold wheels, 17x11 with 50mm backspacing at all four corners:
Old Jan 6, 2018 | 05:04 PM
belairbrian's Avatar
belairbrian
Please post back on how it goes. I'm looking at the ones with black centers and machined lip. But planning on 17x9.5 all around like the stock setup on my 92.
Old Jan 6, 2018 | 09:40 PM
MikieG1971's Avatar
MikieG1971
Thats a sexy pic! Looks like my car.....just better! So you are saying i need 50mm back spacing for 17x11 wheels. Not sure i want 315 up front. Does look tough as hell though!
Old Jan 6, 2018 | 10:24 PM
MatthewMiller
50mm for 17x11 wheels, yes. Thanks for the compliment! If you live anywhere near me (greater St. Louis area), I'd let you try them on your car.
Old Jan 6, 2018 | 10:32 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I swapped my 315 rears up front once...to check out rub, tracking, and ride. I wasn't sure I would want it full-time either. It felt kinda "heavy" though I'm sure it would be great for power cornering or auto-x.
I'm sure lots of people know they reverted from 9.5" fronts to narrower 8.5" on later models due to consumer complaints about "tracking" ... probably in ruts? That added to my concern about fulltime 11" fronts....possibly like you?
So...I ended up splitting the difference (per se). I bought a set of ZR1 replicas but opted for the early C4 offset...though I have an 89. They are the 11/9.5" combo. The fronts sit flush with the wheel well with the rears slightly outside it. Add in the 315's and the back looks really WIDE. I like the conversion because I felt the factory offset has the wheels sitting too far inboard (looks). Even by pushing the front outward, it helps fill up the wheel well IMO.
The only downside is I expected "deeper" rear rims. They have the same lip as the front wheels...which I've gotten used to.
Compared to 60's cars, I wish we could have DEEP deep dish on all 4 corners. Guess I like the tire outboard...with the dish inset.
Old Jan 7, 2018 | 01:22 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Copied this info a few years ago...
1984-1996 Corvette Wheels 1984 (base)
front & rear 15"x7" 17mm
Goodyear Eagle GT, P215/65R-15
These wheels were in the catalouge, but were never installed on any new Corvette.
1984 (base)
front & rear 16"x8.5" 32mm
Goodyear Eagle VR50, P255/50VR-16
1984 (z51)
front 16"x8.5" 32mm
rear 16"x9.5" 38mm (6.7" backspacing)
1985 (base)
1985 (z51)
front & rear 16"x9.5" 38mm (6.7" backspacing)
black painted centers
1986 (base)
1986 (z51)
aluminum centers
1987 (base)
1987 (z51,z52)
grey painted centers
1988 (base)
front & rear 16"x8.5" 50mm
1988-1989 Callaway (b2k)
1988 35th Anniversary Edition
front & rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle ZR, P275/40ZR-17
White Wheels
1988 (z51,z52)
1989 (all)
1989 (pre production zr1)
front 17"x9.5" 56mm (7.4" backspacing)
Goodyear Gatorbacks, P275/40ZR-17
rear 17"x11" 36mm (7.93" backspacing)
Goodyear Gatorbacks, P315/35ZR-17
1990 (base)
1990 (zr1)
1991 (base)
Goodyear Eagle ???, P275/40ZR-17
1992 (base)
Goodyear Eagle GSC, P275/40ZR-17
"SAWBLADES" with cast surface
1991 (zr1)
1992 (zr1)
Goodyear Eagle GSC, P315/35ZR-17
1993-1996 (base)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/45ZR-17
Goodyear Eagle GSC, P285/40ZR-17
1993-1995 (z07)
1996 (z51)
"SAWBLADES" with machined surface
1993 (zr1)
1994-1995 (zr1)
1995 pace car
P275/40ZR-17 B/W Tires
1996 Collectors Edition (base)
front 17"x8.5" 56mm
1996 Collectors Edition (z51)
1996 Grand Sport (coupé)
rear 17"x11" 50mm (7.93" backspacing)
1996 Grand Sport (convert.)
front 17"x8.5" 56mm
Goodyear Eagle GSC, P255/40ZR-17
Additional information
Link to a 1984-1996 Corvette Suspension Chart
All 1984-1996 Corvette wheels have 5 bolts and the bolt circle diameter is 4.75"
To use 1988-1996 wheels on a 1984-1987 Corvette you need 0.75" spacers.
The 11" wide rear zr1 wheels will fit 1984-1987 Corvettes without spacers.
The 1984 and 1985 wheels were made from an aluminum casting that do not shine much when polished.
Enkei produced the 1986 and 1987 wheels for GM and they were made of an aluminum that could be polished to a high luster. These Enkei produced wheels also were slightly larger on the inside, which means you can use the '88 and later 2-piston front brake caliper with a 13" rotor. The Enkei produced wheel can be identified by a small symbol in one of the slotted radial wheel vents which looks like an "m" grafted to an upside down "J".
Tire Size Calculator
Use the calculator to see what happens to your speedometer reading when you change the size of your tires and wheels. The graphic shows your stock tire selection in an outline overlaid on your new tire selection
Old Jan 7, 2018 | 02:48 AM
MikieG1971's Avatar
MikieG1971
Very confusing.
Old Jan 7, 2018 | 07:14 PM
bob arrowsmith's Avatar
bob arrowsmith
Default zr1 rims
i have zr1 style chrome wheels and tire combo, front 17x9.5, back 17x11 , back tires are 315 s with good tread in great condition off my 96 in the upcoming events southern california section for sale , tires are Sumitomo. if your local it could be worth your while.
Old Jan 7, 2018 | 08:37 PM
GREGGPENN's Avatar
GREGGPENN
Very confusing.
This is probably an easier chart to read.
To Wheels
Old Jan 7, 2018 | 11:40 PM
gpierce's Avatar
gpierce
For you guys running 315s, where are you getting your tires from and what are you using? Seems like not much left out there in 315/35/17 or for 275/40 for that matter.
Greg
Old Jan 8, 2018 | 12:56 AM
MatthewMiller
To be fair, I've been running race-oriented rubber on these wheels (Toyo R888s and Hoosier A7s). but among actual street tires, there is a Sumitomo, a Goodyear Eagle F1 ($$), a couple of Nittos, and (believe it or not) a Mickey Thompson Street Comp. So there is a some selection still available.
PS - I actually think that Mickey Thompson looks like an interesting tire choice!
Old Jan 8, 2018 | 01:09 AM
gpierce's Avatar
gpierce
Thanks I found all those. Aside from the Sumitomo and F1s (which I think are kinda ugly even if they are awesome tires) The rest of those are drag radials. I suppose OK to drive on in dry weather, but what if it rains??
It seems to me these are another of the sizes generally abandoned for 20+s
Greg
