Coolant change
Old Oct 11, 2002 | 04:32 PM
corvette90's Avatar
corvette90
Default Coolant change
How often do you change coolant?
which stuff do you use?
must it be dexcool, or can i use any other antifreeze which is compatible with aluminium?
thanks
Old Oct 11, 2002 | 04:53 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Coolant change (corvette90)
I do mine every 2 years. Pop the hoses, let it run with a fresh water hose to clean it out real well. Then use about 10 gallons of distilled water for a final flush, drain it down 2 gallons, put the orange stuff in and the GM veggie tabs, then top off with distilled water. Make sure and keep the OPTICRAP dry and to burp the system!
Old Oct 11, 2002 | 04:56 PM
Steel Blue 91's Avatar
Steel Blue 91
I would replace what was installed from the factory. My 91 had the green stuff so I replaced it with that (and added a bottle of water wetter). GM did'nt start using dexcool until 95 or 96 so your 90 should have had green coolant in it. I flush and replace the coolant in all my cars every two years (or at a cooling system failure). Did the vette in 06-01 and will do it again in the spring.
Old Oct 11, 2002 | 05:58 PM
corvette90's Avatar
corvette90
Default Re: Coolant change (Steel Blue 91)
yes, i have green stuff in it..
can i use any ethylene glycol based antifreeze(aluminium compatible)?
thanks
Old Oct 11, 2002 | 11:41 PM
qwerty111's Avatar
qwerty111
Yes........
Old Oct 12, 2002 | 12:02 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
http://forums.corvetteforum.com/zerothread?id=406767
Old Oct 12, 2002 | 01:17 AM
ParadiseSD's Avatar
ParadiseSD
Default Re: Coolant change (PeteL)
Yeah about every two years seems about right. I just did a transfusion recently. Boy what a difference it makes.
Old Oct 15, 2002 | 04:53 PM
corvette90's Avatar
corvette90
Default Re: Coolant change (ParadiseSD)
are the coolant supplement pills real necessary?
thanks
Old Oct 15, 2002 | 05:04 PM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
As far as with the "green stuff":
I don't know about "necessary", but why not? Cheap insurance.
As far as with dex-cool:
DO NOT USE THE TABLETS
To Coolant change
