Flushing and Refilling ABS
Old Oct 11, 2002 | 04:36 PM
black86ycar's Avatar
black86ycar
Default Flushing and Refilling ABS
Anything special to consider when draining and refilling brake system on a ABS car?
Old Oct 11, 2002 | 04:49 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Flushing and Refilling ABS (black86ycar)
NO.
Just bleed the brakes like a normal car, RR, LR, RF, LF.
Old Oct 11, 2002 | 05:07 PM
95AquaC4's Avatar
95AquaC4
Default Re: Flushing and Refilling ABS (PTz-92-LT1)
NO.
:yesnod: Always start with furthest away.
Old Oct 11, 2002 | 10:12 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Yes, do not drain your brake fluid. Flush it, with new from the master to each wheel. If you don't know what you are doing, take the car to somebody that does. Will save you a lot of problems.
[Modified by PeteL, 9:12 PM 10/11/2002]
Old Oct 11, 2002 | 10:15 PM
scorp508's Avatar
scorp508
NO.
Well you started with giving him the wrong order. :)
YES, on an ABS car it is different.
My service manual calls for...
RF, RR, LR, LF
Old Oct 12, 2002 | 09:33 AM
95AquaC4's Avatar
95AquaC4
Default Re: (scorp508)
RF, RR, LR, LF
Hmm. Interesting. This is one of those things we've done so many times before that we would not even think of consulting the manual. I always bleed from furthest away to closest. Hope it works....that's how I just bled mine. Too much rain to drive it, but the pedal feels good.
Old Oct 12, 2002 | 05:18 PM
silver & red CE's Avatar
silver & red CE
RF, RR, LR, LF
Scorp,
FWIW, my 96 FSM says RR, LR, RF, LF in both the ABS section and the brake section. Since there's two schools of thought on this and nobody is reporting problems, I figure the real key is to actual flush it.
BTW, as long as you flush the brakes often (once every year or two) there's no need to bleed the ABS pump, it cycles on every start up cycle and circulates the pump's fluid into the regular brake lines. If you haven't flushed the brakes or aren't sure if they've ever been flushed, just do the procedure twice in one month to put the system right.
Eric
To Flushing and Refilling ABS
