EGR Crossover Pipe
Old Jan 10, 2018 | 05:27 PM
81c3's Avatar
81c3
Default EGR Crossover Pipe
On my 86, can this be removed? Damn thing is a PIA !!!! Keep melting the aftermarket aluminum jackets I buy on line... Also, the little sensor... what does that do? Will the car run ok without the both pieces? Of course I will plug the ex & intake manifolds...
Old Jan 11, 2018 | 10:12 AM
mt01's Avatar
mt01
My 86 runs fine without them. I removed the EGR tube, welded the header shut, and got a delete kit off ebay to plug the EGR holes in the intake manifold.
I cut the wire off of the sensor and taped it up.
Old Jan 12, 2018 | 09:21 AM
bjankuski's Avatar
bjankuski
To do it correctly you also need to disable the error code in the chip.
Old Jan 12, 2018 | 02:22 PM
mt01's Avatar
mt01
I'm running a stock ECM and haven't had it throw any errors (no SES light, no codes) without the EGR.
Old Jan 12, 2018 | 05:51 PM
aklim's Avatar
aklim
I think it throws the code UNDER CERTAIN CONDITIONS and doesn't test for function on startup.
Old Jan 16, 2018 | 01:14 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The switch will throw a 34.
FWIW I wrapped the pipe with aluminized fiberglas wrap. Finished with .020 safety wire.
To EGR Crossover Pipe
