Tech 2 GM Chinese clone?
I did a self test of the CANdi module and it passed!
By the way I did not have to turn the ignition on to do the self test or get the green LED to light.
Here is what I found tonight.
OBD I only has 1 ground, so 12 pin adapter connects signal and chassis ground to the Tech 2 cable.
OBD II has chassis and signal ground and they are connected in the cars wiring.
How I was trying to get CANdi module to work:
Nothing on CANdi end of cable.
Boot screen not showing CANdi present, diagnostics for CANdi says it isn't seen.
Here I connected OBD I adapter to end of CANdi cable:
OBD I adapter connected.
CANdi module shows up at boot screen.
Green LED flashes about once every second.
Diagnostic screens for CANdi now present. Hit ENTER, 4, 7 to get to this screen.
POST Results.
Self Test Results.
The weird looking screen is because I have not removed the protective plastic yet.
POST Results.
Self Test Results.
SECTION VI
TROUBLESHOOTING
2005 Tech 2 User’s Guide VI - 15
IMPORTANT
If not properly grounded, the CANdi module will appear to be defective when it is not. The CANdi
module will fail due to improper grounding if you use the 16-pin DLC (J-1962) connector and power the
Tech 2 from an AC/DC power supply. The adapter you use must have a GM part number. Although PVI
adapters are similar to GM adapters, they will not work with the CANdi module.
CANdi Module Troubleshooting Guide
If a CANdi module is not functioning properly, please perform the following tests:
1. Make sure the CANdi module is properly grounded by connecting to a vehicle or by using the 12-pin
ALDL connector, which has the signal and chassis ground shorted.
Tech 2 View:
Computer representation of Tech 2 Screen.
You can control Tech 2 with computer keyboard.
Service Programming System:
If you forget to put security key in PC.
With security key connected.
Not actually connected to car.
Software Download:
Selected Tech 2.
Do not load as version will be downgraded from the English GM 33.004 I am running.
Snapshot Upload Display:
Select Upload from Handheld.
Select Tech 2.
Upload started.
Data screen from snapshot.
Selected parameters for 6 line graph. Tech 2 limited to 3 parameters for graphing.
Tech 2 graph from snapshot.
Service ASR on during snapshot capture, went out next time car started.
