strange water leak
Old Jan 15, 2018 | 01:24 PM
lectroglide's Avatar
lectroglide
Default strange water leak
so we were changing oil on my 95 yesterday got the car up on jacks and started seen water dripping down by and under the black water coolant tank, got under and looked around with the car running and couldn't see anything but the water level looked good, the water on the ground also did not feel or smell like coolant.
so driving home all of a sudden the lower 1/2 of the windshield started fogging up inside "which has never happened" turned on the defroster and it went away>>>>>>>>>>any ideas????
Old Jan 15, 2018 | 01:31 PM
mtwoolford's Avatar
mtwoolford
there's a drain tube from the HVAC plenum in that exact area; if it's plugged even partially, when you jacked up the car, condensate probably migrated to where the suction from the HVAC fan picked it up and blew it up through the defroster vents
there are three or four small drain tubes from the cowl area in front of the windshield and the aforementioned larger one from the HVAC plenum, all of these have to be clear for the system to operate properly and unless yours have been cleaned lately, I can almost guarantee that some are plugged.
Old Jan 15, 2018 | 01:39 PM
lectroglide
thanx, so what is the cleaning process??
Old Jan 15, 2018 | 03:44 PM
mtwoolford's Avatar
mtwoolford
On the large one coming from the bottom of the HVAC plenum, I removed the "gill" aft of the passenger side front wheel; that exposed the large drain tube; it's just rubber and will pull of; mine was packed with foul crap.
The ones from the cowl area are thinner longer rubber tubes and should be accessible from the engine side of the cowl; again they just pull off / push on; alternatively, they could, I suppose, be cleaned from the top with a long flexible wand of some type.
I cleaned all of these after experiencing water on the inside of my car; thinking that I needed to have the windshield resealed, I went to a local, and thankfully honest, glass shop; the owner told me that the usual cause of interior flooding was these drains clogging up....and he was right.
good luck
Old Jan 15, 2018 | 04:37 PM
HonestJohn1's Avatar
HonestJohn1
3rd Gear
Thanks,
Very cool useful information. Ill check mine when it warms up a little.
John
Old Jan 15, 2018 | 05:59 PM
95BLKVette's Avatar
95BLKVette
Originally Posted by HonestJohn1
Thanks,
John
We call these drains cow utters 😂
To strange water leak
