Verifying Meziere Water Pump Functionality
Old Oct 12, 2002 | 01:58 AM
Langadorf's Avatar
Langadorf
Default Verifying Meziere Water Pump Functionality
Is it possible for LT1 Meziere water pumps to come wired backwards from the factory? What behavior would a backwards running pump exhibit? When running the pump w/ the engine off but warm and the radiator cap off, I can see a stream of water coming from the head-head crossover tube into the radiator. The stream was coming out slower than what I had seen w/ my stock gear driven pump. With my stock pump, the stream would be blasting out of the hole. Also, it seems that the output hose from the radiator gets hotter sooner than the one on the input side. Is this normal? Are there any other ways to verify the pump is working correctly?
I have the blue wire going to a 12v ignition source and the black wire to a ground as per the instructions. Also, the plug can only fit on one way, so I couldn't have wired it backwards.
Thanks for any ideas!
Old Oct 12, 2002 | 12:30 PM
Langadorf's Avatar
Langadorf
Default Re: Verifying Meziere Water Pump Functionality (Langadorf)
TTT
Old Oct 12, 2002 | 01:37 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Meziere did have some quality control problems that caused a defect in the pump I got. Shoot them an e-mail explaining your problem, I'm sure they will help. The did a great job for me correcting my problem.
[Modified by mackeyred96, 12:38 PM 10/12/2002]
Old Oct 14, 2002 | 02:52 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Reverse the wire connections and see if there is an improvement. One of the items in the instructions is to check to make sure the pump is turning in the correct direction. (I skipped this item too)
Old Oct 14, 2002 | 08:08 PM
hotwilzz's Avatar
hotwilzz
I have a remote located CSI wp on my 86 and found that it had to be primed(meaning the cooling system had to be very full for the pump to be able to grab and then push the fluid) or I experienced the trick that you describe also. just a thought.
Old Oct 15, 2002 | 01:04 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Verifying Meziere Water Pump Functionality (hotwilzz)
:eek: which way is there LT1/4 pump supposed to turn?
Stock direction or opposite?
Old Oct 15, 2002 | 01:05 AM
scorp508's Avatar
scorp508
hotwillzz,
any pictures or information on your setup? The less pullies turning the better for me! :)
Old Oct 15, 2002 | 11:50 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Verifying Meziere Water Pump Functionality (BrianCunningham)
It says for sure in the directions, but I want to say it is supposed to turn counter clockwise. I am not possitive though and my directions have long since been thrown away. If it is turning correctly, you should see a steady stream coming out of the return hole in the coolant fill tank and the water will be streaming from right to left.
Chris
Old Oct 15, 2002 | 04:39 PM
BrianCunningham
Default Re: Verifying Meziere Water Pump Functionality (Vette92)
thanks :cheers:
Old Oct 15, 2002 | 05:22 PM
John Row's Avatar
John Row
Chris
Counter-clockwise is what I remember. Call them 1-760-746-3273.
Water should be shooting from the top tube below the cap seat (not the overflow tube).
Don't run the engine until it is working correctly.
Old Oct 15, 2002 | 08:11 PM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Default Re: Verifying Meziere Water Pump Functionality (John Row)
my friends z28 pump was grinding on the housing plate of the mezziere, he loosened th ebolt and made sure it spun freely. All i know it water blasts outta mine and the car stays cooooold no matter how hard i drive. Mezz rocks.
To Verifying Meziere Water Pump Functionality
