4.10s with a auto?
Old Oct 12, 2002 | 10:59 AM
Quick1's Avatar
Quick1
Default 4.10s with a auto?
Anyone running 4.10s with an A4? pro and cons! Thanks
Old Oct 12, 2002 | 11:29 AM
cprgmr's Avatar
cprgmr
Default Re: 4.10s with a auto? (Quick1)
I think 4.10s would be a pretty steep gear (if they make them for a Dana 36). I'm turning 2600 rpms at 70 mph on the highway with the 3.54s.
Old Oct 12, 2002 | 01:01 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mackey is running a 4.10 gear in his '96, but he also is running a taller tire(28").
Old Oct 12, 2002 | 01:34 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 4.10s with a auto? (Mr Mojo)
Thats right. :)
Old Oct 12, 2002 | 03:10 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 4.10s with a auto? (cprgmr)
Old Oct 12, 2002 | 06:37 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: 4.10s with a auto? (Zora)
wow mack i didnt notice you had that steep gear in the car 1st gear must be quick as hell :cheers:
Old Oct 13, 2002 | 12:37 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: 4.10s with a auto? (CORKVETTE1)
If it is a real street car, I would stay away from the 4.10's. 3.73 is pretty steep, but some like them. Do the math and find out how many rpm's you will be running at various speeds. Then be honest with yourself, how often does this car see the track? Do you take it on road trips? Do you have a stall convertor? A good convertor and a numerically lower gear may also get you what you want. I have a Dana 44 with 3.33's and a 2400 convertor. This is in an LT-1 that makes about 365 rwhp. I can pull high 1.7 60 ft times on Nitto's. (not drag nittos) My low end doesn't seem to suffer to much, even though my gear and convertor are very mild. The car is a blast to drive and I can take it on the freeway and run 80 mph and get over 20 mpg. Good luck !!!!!
Old Oct 13, 2002 | 03:36 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: 4.10s with a auto? (mackeyred96)
Thats right. :)
That is steep. Dad was running 4.56 with the Chevelle and a 700R4. The best he got was 11.5sec@117
We switched to 3.90 gear and it now goes near flat 11.4@119 pulling the front off the ground. 60' are low 1.6s.
However, the times may be the same. The car is MUCH easier to drive on the street now and much more fun. Before you couldn't take out without chirping the tires.
I think he would be still even quicker with around 3.33 or maybe 3.07 gears.
When I had probuilt build my tranny he said for the strip you want 1st gear to be between 9:1 and 12:1. So with 3.06 1st in our 700r4 you need ~3.07:1 to be at the lower end of the spectrum and 3.73:1 to be at the upper end. Now you can lower or higher these values with tire height, but just for sake of discussion this is a pretty good rule.
4.10 gears would put you at 12.5:1 which is at the upper end.
I personally think the lower gear you have the harder it is to hook hard. :cheers:
Old Oct 13, 2002 | 04:47 PM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Default Re: 4.10s with a auto? (ski_dwn_it)
i suggest 3.73 s for an auto.
Old Oct 13, 2002 | 06:26 PM
vader86's Avatar
vader86
4.10 is better for a 6speed, not an A4. Id get either 3.54 or 3.73 in an automatic.
To 4.10s with a auto?
