Window is down and will not roll back up, need help.
Old Oct 12, 2002 | 12:23 PM
Toms86vette's Avatar
Toms86vette
Default Window is down and will not roll back up, need help.
Yesterday I rolled my window down and I heard a noise. I tried to roll it back up and could hear the motor run but the window would not come back up. This morning I took off the drivers side door panel and could not go any futher due to the shelding that hid everything. I've taken all the bolts loose that I can see and the shelding for the door handle and the lock are still in place. Does this need to come off? Can I put the window back on the track without removing the sheilding? I need to get the window up before it rains again. Thanks for helping. :confused:
Old Oct 12, 2002 | 12:40 PM
VetteNoob's Avatar
VetteNoob
Default Re: Window is down and will not roll back up, need help. (Toms86vette)
The 'tape' broke. Same thing happened to me. You will need to take your door panel apart and replace the ribbon/tape.
Old Oct 12, 2002 | 12:41 PM
Toms86vette
Come on guys, I know that someone has had problems with their windows. Did anyone repair their own? Sure could use the help this morning. Thanks :jester
Old Oct 12, 2002 | 12:43 PM
Toms86vette
Default Re: Window is down and will not roll back up, need help. (VetteNoob)
Is there a thread that shows how to do this? :jester
Old Oct 12, 2002 | 12:46 PM
VetteNoob's Avatar
VetteNoob
I couldnt find one when I was looking. I do however have a service manual that was pretty helpful. I dont believe the Haynes are of any use in this situation.
The ribbon itself was only like $15, but I ordered it from Jeff Kopp along with a few other things to make shipping worth while. I can see if I can find someone with a digicam and I can take pics of the pages you need or just type it out if that will help.
Old Oct 12, 2002 | 12:53 PM
Toms86vette
VetteNoob, That would be a great help. I'll look through everything I can find. Thanks again, Tom. :seeya
Old Oct 12, 2002 | 01:02 PM
JonM's Avatar
JonM
Check this out .... http://www.madvet.com/pdf/603939.pdf
Old Oct 12, 2002 | 01:04 PM
VetteNoob's Avatar
VetteNoob
Default Re: Window is down and will not roll back up, need help. (JonM)
Damn Jon. You saved me some typing. :D
Old Oct 12, 2002 | 01:18 PM
JonM's Avatar
JonM
No Charge .... :D
Old Oct 12, 2002 | 01:20 PM
Toms86vette
Thanks for the help and information. Looks like I got a lot of work ahead of me. One day I would like to work on what I want. But with each repair I am getting closer. Again Thanks to you both. :jester
To Window is down and will not roll back up, need help.
