Lubing the C4-Where?
Old Oct 12, 2002 | 03:17 PM
Frank C's Avatar
Frank C
Default Lubing the C4-Where?
So I'm looking at the front underside of my 91 because it's easy now with the new lift and I notice lube fittings at the tie rod ends, etc. Good grief, how could I have forgotten to lube during the last oil change. I didn't know you still had too. Anyway, where are all the lube fittings and how many are there on this 91? I've found only four.......Thanks, Frank
Old Oct 12, 2002 | 03:23 PM
CLUTCH^Master's Avatar
CLUTCH^Master
Default Re: Lubing the C4-Where? (Frank C)
I think there are 2 up front and 4 in the back just look for the greese fittings where the tierods are, also you might want to lube up the u joints as well. Oh yeh its realy easy to get to the front fittings by simply poping the hood, i found this out after an hour of trying to reach the fittings. :mad
good luck :cheers:
Old Oct 12, 2002 | 07:07 PM
ONEVETTE's Avatar
ONEVETTE
Cruising
Default Re: Lubing the C4-Where? (CLUTCH^Master)
Are the same lube fitting located on a 1994. I just starting doing oil changes myself and would like to take over lubing fitting also.
"TVETTTE"
:chevy
Old Oct 12, 2002 | 09:53 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
On a 91 you should have 6 up front 3 each side, Upper & Lower Ball joints and Tie rod ends none in the rear, if some one has changed your u-joints you could have them also.
94 only has upper & lower ball joints..
[Modified by We Gone, 8:55 PM 10/12/2002]
Old Oct 13, 2002 | 09:54 AM
ToniH's Avatar
ToniH
Default Re: Lubing the C4-Where? (We Gone)
My '91 tie rod ends do not have grease fittings :confused:
I only found fittings on the ball joints and u-joints. I don't think GM u-joints have fittings though. I have changed them already twice because I didn't relube the first ones during 37K miles and surprice! they went bad. :rolleyes: Learned from that ;)
Toni
Old Oct 13, 2002 | 11:06 AM
Frank C's Avatar
Frank C
Default Re: Lubing the C4-Where? (ToniH)
Thanks Guy's. I'll be on it today....Frank
Old Oct 14, 2002 | 06:25 PM
TIMSPEED's Avatar
TIMSPEED
What would lubing these points do for me? (I'm not sure if I NEED to, but how would I know?)
To Lubing the C4-Where?
