4:11 city driving
Old Jan 25, 2018 | 03:58 PM
johno504's Avatar
johno504
St. Jude Donor '19
Default 4:11 city driving
considering swap to 4:11 in my LT4. object is reduce amount of shifts for round town driving. will I be able to start off in second and make one up shift ( 4th) for most daily traffic situations ? I'm jacked up on chemo and the constant effort of the 6mt wears me out pretty quick. if this is not a viable option, thinking of switching to an 08+ paddle shift car.
Old Jan 25, 2018 | 06:23 PM
blackbelt's Avatar
blackbelt
short answer. Yes. Although you can easily do that now with stock gear. 4.10s will certainly make the take off in 2nd gear easier on you and the clutch though
Old Jan 25, 2018 | 06:52 PM
ddahlgren's Avatar
ddahlgren
Why can't you do the same thing with 1st and 3'?
Old Jan 25, 2018 | 08:13 PM
383vett's Avatar
383vett
Old Jan 25, 2018 | 08:55 PM
johno504's Avatar
johno504
St. Jude Donor '19
Originally Posted by 383vett
1 to 3 works ok for me, I spose I am wishing for a ZF powerglide. am not going to give up on Corvettes just trying to make experience a little bit more relaxing stop light to stop light. can anyone tell me the useful mph range in second with a low gear ? can I run 0 to 40 or so in just second ? with the 4:11 I would think that fist would be so short as to be almost useless. what this boils down to is I basically want to drive in traffic and stay in second without shifting.
Old Jan 25, 2018 | 10:19 PM
Jeffs82c3's Avatar
Jeffs82c3
4.11 around town is fine, but not for highway cruising...
Old Jan 26, 2018 | 03:00 AM
STL94LT1's Avatar
STL94LT1
M6 + 4.10 = 1800 rpms at 70 mph, very highway friendly.
Old Jan 26, 2018 | 08:11 AM
9T3VETTE's Avatar
9T3VETTE
^^Agreed, 4.10 is great for highway work.
Lots of shifting around town if you go 1 - 2 -3. Usually 1st to 3rd works best for me.
Old Jan 26, 2018 | 08:42 AM
cv67's Avatar
cv67
St. Jude Donor '05
dont think 2nd gear@40 with 4.11s will work for you. It wont be bad but think youre better off going 1-3 and healing up. Frustrating being sick to where you cant drive believe me. Get better
edit if you decide to go 4.11 anyway no 1st wont be useless, have it with a 26 in tire its just right
when you get better add some stroke, a port job & solid roller youll fall in love with that 4.11
Old Jan 26, 2018 | 11:04 AM
mrodoc's Avatar
mrodoc
I have a 1994 with a 4L60E, 3000 stall TC and 4.11. Even though I don't have a manual, go for it and don't look back. The smile per mile is worth it.
Old Jan 26, 2018 | 03:09 PM
MatthewMiller's Avatar
MatthewMiller
The ZF6 is geared a bit tall in 1st and 2nd anyway, and the first five ratios are fairly close compared to most street cars. Combined with your LT4's higher redline (I think it's 6400rpm?), that means the car should respond well to 4.11s. That said, even with the stock 3.45 gears, that car was designed to be launched in first and skip-shifted directly to 4th gear at low speeds. Considering that the car redlines at something like 60mp in 1st with the stock gears, I think you could save your money and just really use 1st for and then either pick 3rd for driving in neighborhoods or 4th for streets that have 35mph limits or higher.
Old Jan 27, 2018 | 09:11 AM
johno504's Avatar
johno504
St. Jude Donor '19
thanks , johno
To 4:11 city driving
