87 Driver's headlight motor
Old Jan 27, 2018 | 12:35 AM
RTDriver0217's Avatar
RTDriver0217
1st Gear
Default 87 Driver's headlight motor
87 Vette - recently pulled headlight motor on driver's side. Had Corvette Central rebuild it, had 1 new pigtail put in as well. Re-installed the headlight and it worked fine. Car sat for a month, used headlights and driver's side goes up ok but does not go down when turned-off. Sometimes it'll go down if motor is tapped. Other times, if the car sits for 20-30 minutes (everything off), it'll go down on it's own. Electrical or think it was a faulty rebuild? Still under warranty. A bit stumped here. Thanks for any thoughts....
Old Jan 27, 2018 | 11:01 AM
xrav22's Avatar
xrav22
Try cleaning your connector, fixed mine.
(Do not use a wire brush) It is energized just use cleaner and sandpaper.
