OBD 1 Codes
Old Feb 10, 2018 | 01:01 AM
71CamZ's Avatar
71CamZ
7th Gear
Default OBD 1 Codes
Hello,
I am new to owning a Corvette, I have an 86 and I keep hearing how people pull codes to diagnose there cars, I bought an OBD 1 code reader and plugged it in hoping to see what's wrong with my car. On the dash it has a cover that just says Corvette. Also when I start the car nothing lights up or does anything on the panel, is this normal or is something wrong with the car?
Old Feb 10, 2018 | 05:52 AM
JoBy's Avatar
JoBy
Where is that Corvette cover?
Old Feb 10, 2018 | 08:06 AM
playsdixie's Avatar
playsdixie
if you had a code, the check engine light would be on....jump a paper clip between pin A and B on your ALDL...under the dash....count the flashes....everything in threes....three 12's and then three sets of any codes....it will end with three 12's again....1 flash 2 flash, 1 flash 2 flash, 1 flash 2 flash....do a search on this site, you;'ll find more specif info on how to do this....clear them by disconnecting the neg terminal...an 86 has a separate wire off the neg terminal that would do this....and most importantly,,, get a FSM
Old Feb 10, 2018 | 10:18 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
That cover MAY be blocking out your DIC lights. Most are opaque and will still allow service lights to be seen. You may have one that is too dark.
Old Feb 10, 2018 | 10:51 PM
71CamZ's Avatar
71CamZ
7th Gear
I tried to pull it off one day with a small flat head screwdriver but stopped right away because I was afraid of breaking it. When I put the key in the ignition I can even see any lights. is there a way to get it off with out breaking it?
Old Feb 10, 2018 | 10:52 PM
71CamZ's Avatar
71CamZ
7th Gear
Its right above the radio where all the warning lights are.
Old Feb 10, 2018 | 10:56 PM
71CamZ's Avatar
71CamZ
7th Gear
I posted a picture I hope this helps
To OBD 1 Codes
