Ok, so getting to know my '93 that I just bought, I have a question.
'93 LT1 w/ 6spd man and around 150k miles
When the car is started up and still cold, it seems to have extremely high oil pressure. At a 1000-1500 RPMs, the oil pressure gauge needle is at 3/4 reading. 2000 RPMs or more, and the gauges needle is buried as far as it will go. After the car properly warms up, at 1000-1500 RPMs, the needle is only showing a reading of 1/4, and at WOT, the pressure is only at the 3/4 mark. (I hope you guys and girls understand what I'm saying here. If need be, I can take pics of the gauge showing what I'm talking about)
Is this something I should be concerned about? I do not know exactly what brand or weight oil is in the car. All I do know about it is it looks new and very clean. Also, when looking at the top of the heads though the oil cap hole, the top of the heads are also very clean looking. The car runs great with no knocking or tapping of any kind.
You will want to test the pressure of your engine independent of your analog gauge. The fact that you are getting wild swings tell me that your gauge is messed. The gauges are not really very accurate.
So, 1) clean your contact points, 2) you could replace the sending unit, 3) test independently.
I don't know if I would call what I'm seeing as "wild swings" as the amount of pressure shown is in relation with the RPMs of the car. More RPMs, the pressure goes up, less RPMs, the pressure goes down. It's just the huge difference in pressure readings between being cold and warm that has me concerned
I'm basing it off my L98. There is a sensor above and behind the distributor that is part of a tree. Unscrew one of the sensors on the tree and plug in an oil pressure gauge. The other one is near the oil filter. Plug it in there and do the things that make your oil pressure fluctuate. That will tell you if you have an accurate gauge or not. If your gauge is flickering, nothing we do will work, short of fixing the sensor or gauge. The mechanical oil pressure gauge will tell us if there is a problem we are going to chase or we have created a problem to chase.
Since you don't know what oil is in the car, I'd do a change first. Then see what happens. The previous owner might have put much higher viscosity oil in there.
Good point. I know of people who put high viscosity oil and some of those "Motor Honey" or STP to thicken the oil just so it doesn't sound noisy at time of sale.
