I’m gonna replace my mass air flow sensor and I was wondering which brand will work the best.
Hi
Just buy the correct year MAF sensor for your C4s manufacture date, there are differences over the years. and any old MAF sensor will not work.
Note stay away from the non hot wire MAF's out there, they are not suited to C4's with a hot wire type.
I made that mistake buying from Corvette Central, they sent some cheap copy that loos totally different inside. They wont warranty electrical items, i found out later that the one they sent will not work on my C4.
Needless to say i will never deal with Corvette Central again.
So look at the MAF you are buying, is the number on the underside the same? does it look identical with air venturi and hot wire?
If not look else where.
I have exchanged a few emails with Spectra Premium on their new MAF to make sure the burn off circuit is in place and activated. I gave up when no one could tell me.
Ive seen issues with some of the reman units not having the circuit and overall bad quality control.
Id buy a brand new unit from someone that could confirm the burn circuit - can anyone here recommend a specific brand?
Just looked at the BlowerWorks unit and it looks nice but requires a software change.
Well the reason I’m looking to replace it is because I’m getting code 36 and have ordered new relays but I’m reading that people have that code and replace the relays only to have code 36 pop up again. I was hoping someone who has used the computer chip style MAF from Spectre would be able to review it.
The MAF in my 1988 went bad and I and replaced it with one I bought from RockAuto.com. When I looked at the data coming out of the new MAF everything looked good but I was getting a code 36.
It was pretty obvious looking at the new MAF that it didn't use a hot-wire style sensor so the MAF burn-off test probably wasn't needed or supported.
I purchased TunerCat and reprogrammed my ECM to eliminate the MAF burn-off test and while I was at it I reprogrammed the 4+3 overdrive to default to OFF. I may also reprogram to eliminate the VATS if it ever starts causing me trouble.
All the above is to say, getting TunerCat is a way to eliminate the code 36 and provides other benefits too.
Take a look at my website for an alternative MAF - slot style and indestructible !
Also eliminates the burn off relay !
I put a Blowerworks MAF sensor on my 89 vette about 7 years ago and it's one of the best mods I have done to my car.. Half the price of a new Bosch maf ( If you can find one).. You plug in the maf sensor , then insert their bin file into your tune and never worry about a MAF sensor again....Plus , the housing is made of aluminum... WW
I am diagnosing my MAF on a 96. The red wire is hot and remains around 12.4 volt engine running and not (ign on). The black is ground. he yellow reads 5.4v with ignition on, engine not running and just under the red voltage when engine is running. No fluctuation with engine speed. Is that the correct voltage for the yellow wire?
Thanks Bill. No codes? Did you buy this one to fix a specific problem?
OK, I purchased this MAF via Amazon using the part number that Bill outlined above. The thing cost 69 bucks with free shipping if you are a Prime member.
So far I have gone through about a dozen start cycles while driving around and so far, no friggin code 36!
The unit is nearly identical to my old Bosch unit but is lighter in weight. The wire setup in the air flow is different, oriented sideways in the airflow and smaller.
Car seems to idle better but that may simply be because the old one was dieing. I also updated the O2 sensor for good measure. At 63000 miles it appeared to be original.
So far, I am quite pleased with the result and will keep this thread updated with my experiences.
