Light Problem
Old Feb 22, 2018 | 09:35 AM
jkann1's Avatar
jkann1
Default Light Problem
Hi all I took my 84 vette out it was a nice day,, I notice that the passenger side Headlight and turn signal and marker lights don't work anymore the head light comes on. but the motor I guess is stuck in the up position I looked at the wires and connection and the bulbs all seem to be ok but I notice that one of the marker shows very dim lite... any ideas Thank you for your time...
Old Feb 22, 2018 | 02:59 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Since your marker light is dim, there's a good chance you have a bad ground at G106. This ground connection is also used for the RH headlight motor. You'll find this ground connection on the bar that goes between the frame rails, located between the radiator and the engine. It's near the RH end of that bar.
