1984 c4 manual trans
Old Feb 25, 2018 | 07:58 PM
rookie 84's Avatar
rookie 84
7th Gear
Default 1984 c4 manual trans
where is the clutch saftey switch on 1984 c4
Old Feb 25, 2018 | 08:43 PM
383vett's Avatar
383vett
By the clutch pedal. Look 1/2 way up the pedal and you'll see it.
Old Feb 25, 2018 | 09:12 PM
rookie 84's Avatar
rookie 84
7th Gear
Default c4
thank you very much
Old Feb 26, 2018 | 11:21 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Has your safety switch gone bad? If so, you can just jumper it on the plug. The old switch will no longer work at that point. You will have to engage the clutch or put the transmission in neutral each time to start the engine. On my 85 that switch is so far up under the dash, it's almost impossible to remove it. When my neutral safety switch was acting up, I just unplugged it and jumpered the plug where the switch was connected.
Old Feb 27, 2018 | 06:23 AM
rookie 84's Avatar
rookie 84
7th Gear
Default c4
thank you i will try that
To 1984 c4 manual trans
