When to replace control arm bushings
My questions are, since I'm in this deep, should I go ahead and replace the control arm bushings while I'm at it? What would indicate a need for replacement? I've read that poly bushings require regular disassembly to grease them, is that true?
Thanks,
Reed
with 120K miles they most likely all need to be replaced. I've been slowly doing sections of mine. 4 years ago did did the dog bones in the rear as well as the sway-bar and end-link bushings.I don't see how you would be able to "re-lube" pressed in bushings after assembly. All of the advice I received at the time said to just be use a lot of the special lube supplied at the time of initial assembly which I did and have not had any squeaking issues. This past fall when I had the rear end swapped out we did the bat wing bushings as well. To me that made a significant difference in the feel of the car.
Thanks,
Reed
Did my front and back to poly bushes at 170,000 miles.
The front control arms on my 85 the bushes had minimal wear, the rear however were pretty bad. The dog bones (trailing arms) were fine however the strut rods were shocking, the inner most bushes were down to the metal sleeve.
Now it is not an easy job, you will need a drill and large Vice and sockets for pressing old bushes out and new ones in.
Tip cut the outer rubber off the bush, then drill holes through the old rubber bushes with a small drill bit. Hammer a flat blade screw driver through and its easier to pry them out, or use a vice and socket to press them out.
Apply lots of the lube in and out the bushes, its been a few years since i did mine and no squeaks. They say after 10 years they may need to be greased again, i did think of fitting grease nipples for future use but never did it.
The rear is quite easy however pay attention to the inner strut rod, camber bolt end washers take a picture when removing them from the car so you know where they go.
Now the Front suspension, removing the upper control arm bushes was a real pain. Remember to drill lots of holes in the rubber bushes be careful not to damage the aluminum!!!!! even after drilling lots of holes at each end they are long bushes. Takes a lot of effort to remove them with a vice and sockets, Assembly needs a piece of metal to support the A arm when installing the new bushes. If you do not use a support on your A arms you will destroy your upper A arms.
Good luck, its a job that needs doing but will take a lot longer than you thought it would.
The prothane bush kit i got was for the entire car (see link below), it came with bushes for all years C4. Unlike some other kits you wont need to stop and buy bushes for your particular model C4.
https://www.ebay.com.au/itm/Prothane...EAAOSwEzxYekgL
I don't even recommend poly bushings for the rear trailing arms. The only really proper alternative to stock rubber bushings there is rod-ends. I've recently switched over from stock rubber to Banski rod ends, and they don't seem to hurt the ride quality or noise at all. They do seem to control rear steer under power and braking somewhat better, based on one day of autocrossing.
If only there were an affordable spherical bearing solution for the rear....
I fitted Banski trailing arms and Banski strut rods with heim joints, i hated the offset camber bolt shifting after wheel alignments. I can now set my camber spot on and it does not change.
I found the poly bushings stiffened the rear suspension quite a bit, they resist movement especially at the dog bones.
Have no complaints about the poly bushes on the front suspension.
I avoid spherical bearings on street driven cars because they don't really last at all.
To the OP's question, if you're in there, replace everything that moves, and do it all at once, or in quick succession. If you do that, you'll end up with essentially "new car handling." If you replace the most worn out part and drive it, the rest of the thing will still be loose and shakey, and that will stress and wear your new parts much quicker than if you replace everything at once.
If it's a daily driver and you're sensitive to down time, consider getting "spares" of the control arms and dog bones and other parts. Take your "spares" with new bushings and ball joints to the machine shop, get them refreshed with new parts. Then the "repair" is merely swapping parts. That's far easier than pulling the thing apart (dealing with 30 year old fasteners that might be seized or damaged), taking the parts to the machine shop, waiting on them to finish and putting it back together. You take the variable time that's out of your control out of the equation with a set of spares. I even keep spares for vehicles that are popular among my friends and family, to facilitate "suspension rebuild jobs" every 100K miles or so.
Hi
The rubber boots supplied by Banski work well, sealing the heim joint from water and dust.
You can also cover the boot with wax or grease to protect them further,
Lee link below... look at the photos
https://www.banskimotorsports.com/c4-corvette-trailing-arms.html
The only difference really in installing these is drilling for the grease fittings and then pinning the upper control arm nuts.
Got them in two race cars and a street car.
