Super t-10 trans in a c4
Old Oct 14, 2002 | 10:57 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Super t-10 trans in a c4
Is it possible to install a super t-10 in a c4? From what I know, a doug nash is a super t-10 with an overdrive attached on the end. Now would I be able to put any old t-10 in my car with no other modifications except driveshaft? Also, if I decided to, can I buy an overdrive and attach it to the t-10? TIA
Old Oct 14, 2002 | 10:59 PM
scorp508's Avatar
scorp508
The 4+3 is a super T-10 with the CC gear ratio set. You would need to custom fab a new tailshaft in order to mate with the torque beam.
Old Oct 14, 2002 | 11:11 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Super t-10 trans in a c4 (NUckINg FuTS)
I'm curious why you would want to, isn't this basically what you already have? Last winter i started to try and make a T-5 5 speed fit but gave up because of the linkage and the attaching the beam.I decided to stick with the 4+3 until i can afford a 6 gear. My car makes alot of power and i haven't had a tranny problem yet :cheers:
Old Oct 14, 2002 | 11:22 PM
NUckINg FuTS
Default Re: Super t-10 trans in a c4 (atotalnincompoop)
I have an auto actually
Old Oct 14, 2002 | 11:41 PM
atotalnincompoop
silly me, there are always used 4+3's complete on e-bay, my advice would be to buy a complete set up, one that you know will fit and work well right away. its tight under there, i wouldn't want to have to fool around with it too much :cheers:
Old Oct 15, 2002 | 12:11 AM
mooncricket's Avatar
mooncricket
There are about three pretty good deals on some ZF6's on ebay right now, I don't know what your budget looks like. The first one looks like a good deal so far, reserve is met. One of the other ones comes with all of the conversion parts.
I know you've been looking for a manual to replace your auto, check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1868130815
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867427190
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867196421
There's also a 4+3, but it looks pricey:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1868628722
To Super t-10 trans in a c4
