1995 corvette considering 4:10 gears
Old Mar 10, 2018 | 07:26 PM
PhilA's Avatar
PhilA
4th Gear
Default 1995 corvette considering 4:10 gears
I'm considering adding 4:10 gears to 1995. Thoughts?
Old Mar 10, 2018 | 07:38 PM
striper's Avatar
striper
I have two. 4.10's are high for a street car. You are in the wrong forum.
Old Mar 10, 2018 | 10:29 PM
Moved to the C4 Tech/Performance Section.
Old Mar 10, 2018 | 11:38 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Why do you want 4.11? Any other mods to your Vette.
Old Mar 11, 2018 | 08:48 AM
C409's Avatar
C409
..... 6speed ? Yes ! ... A4 track , Yes ! ... A4 street , Not so much ! ..... That said , my '87 w/TH400 A3 has 4.30's but it rarely sees any street duty ... 50 mph @ 3000 rpm can be annoying .....
Old Mar 12, 2018 | 02:20 PM
mrodoc's Avatar
mrodoc
1994 with LE2 build, 3000 stall TC. I'm running 4.11 with a 4L60E.
At 2000rpm I'm running 53mph in 4th gear. (yes I've had the PCM updated after the gear switch).Just about 80mph at 3000. I do very little highway driving, but I don't find the 4.11 any problem, and I just love the low end grunt...Just my opinion. So, I would say go for it.
Old Mar 12, 2018 | 03:58 PM
frankinvett84's Avatar
frankinvett84
Have 'em.... Love 'em... do you like smoky burnouts???? If so, get 'em... Speedo is off about 20 miles per hour @ 55. I believe the Im going to get the Daytona digital device because I might wanna try different tire diameters in the future.Rear end gears are probably the best seat of your pants mod you can do. In my opinion.
Old Mar 13, 2018 | 10:49 AM
blackbelt's Avatar
blackbelt
Need to be a bit more specific on your goals and desire for car as well as details. Is it auto or manual? Street driven or track only?
4.10s in a 6 speed car that is street and track driven...no problem... 4.10s in an auto car that is street driven... you may hate life
Old Mar 13, 2018 | 02:18 PM
383vett's Avatar
383vett
4.33 auto perfect. 6700 rpm through traps at 131 mph in third gear. No street driving unless you count the return road.
Old Mar 13, 2018 | 02:44 PM
PhilA's Avatar
PhilA
4th Gear
Default considering 4:10s for 1995 corvette
Hello,
First of all I want to thank everyone that has responded. I think Corvette owners are a special breed! This is my first experience with Corvette Forum, so please excuse my remedial questions. I'm in my 60s. I've had this '95 LT1 6 speed for 17 years. it's fun, but acts like a touring car. Someone told me to get 4:10s which would provide more life. I wasn't sure if that was worth considering and unsure of what would be a reasonable cost to have it done. So thanks for your suggestions!
thanks,
Phil
Old Mar 13, 2018 | 05:20 PM
vader86's Avatar
vader86
For an M6 car, yes, its worthwhile to have this done. Go ahead and ask some local shops.
You really want to find a shop that you know has done this before.
Old Mar 13, 2018 | 05:23 PM
PhilA's Avatar
PhilA
4th Gear
Default 4:10 gears for ‘95
Thanks for the suggestion. I live in Punta Gorda, Florida. I’ll ask around!
Old Mar 13, 2018 | 07:03 PM
PhilA's Avatar
PhilA
4th Gear
No other mods, except for Borla exhaust and upgraded struts. thanks.
Old Mar 14, 2018 | 07:51 AM
C409's Avatar
C409
..... The gear set will cost $3-400 ... bearing install kit about $150 ... R&R your diff will depend on the shop's labor rate and whether or not you have all the u-joints changed while its apart ... WAG $400-1200 ... gear change and set-up labor $3-400 .....
Old Mar 14, 2018 | 09:12 AM
mrodoc's Avatar
mrodoc
Old Mar 14, 2018 | 09:17 AM
mrodoc's Avatar
mrodoc
If you can do some wrench turning, it's not difficult to drop the diff, take it to a reputable shop to have gears and rebuild kit installed, and put diff back in yourself. I did need extra hands just to line it up properly when raising it back into place. The rest I did myself. There are some pretty good DIY videos out there.
To 1995 corvette considering 4:10 gears
