89 Hood Prop basic question
Old Mar 20, 2018 | 07:39 AM
JasBass's Avatar
JasBass
Default 89 Hood Prop basic question
So i'm finishing all the little loose end projects on the car. I bought the car from the PO with a BPP AIR delete already done on the car. But the hood prop is garbage and doesn't telescope. It looks like someone has tack welded it or something so that it doesn't retract. So I have to pop it off the top nub and lay it next to the Alt to get the hood shut. So for those who have the BPP delete, would a factory replacement prop clear the alt or do I need to go to a different style?? Throwing in some pics just for reference
Old Mar 20, 2018 | 10:13 AM
WVZR-1's Avatar
WVZR-1
I would think you have no issues with an original service replacement for a hood support. I don't have a car with the equipment list you mention but I can't imagine issues!!
Old Mar 20, 2018 | 01:33 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
I did the AIR delete bracket on my 88. It does push the alternator over a little more than stock but there is no problem with the hood prop. I just replaced my prop and it works fine.
Old Mar 20, 2018 | 01:36 PM
joeld's Avatar
joeld
I replace mine several years ago with a Strong Arm #a4972 from Advance Auto. Works fine.
Joel
Old Mar 20, 2018 | 02:02 PM
mlm0's Avatar
mlm0
I have 89 and did air delete myself and the hood prop will fit just fine
Old Mar 20, 2018 | 02:41 PM
JasBass's Avatar
JasBass
Awesome! Thank you all, I truly appreciate it
To 89 Hood Prop basic question
