Manual Shifter Pull Up Ring
Old Mar 20, 2018 | 02:24 PM
rblakeney's Avatar
rblakeney
Default Manual Shifter Pull Up Ring
1989 manual six speed original.
Does anyone know the hex key size to loosen the reverse pull up ring on the shifter?
Is it a hex key or something else?
Dang thing is small.
Old Mar 20, 2018 | 03:55 PM
rblakeney's Avatar
rblakeney
OK, found a reference to 1/16 inch. I do have a Hex wrench in that size but it will not insert - screw is probably buggered. I ended up using a very small Torx which is not labeled. Worked fine.
To hijack my own thread, I went ahead and removed the rubber shields and lubricated all shifter parts I could reach with white lithium spray. Smoothed out the shifter a lot but there still seems to be a lot of slop forward and aft.
All of this to replace the shifter boot with a new piece of leather.
Old Mar 20, 2018 | 04:41 PM
WVZR-1's Avatar
WVZR-1
In this thread .077 is mentioned and I last did the lift-ring in maybe '06 or '07 and I don't recall. I'd have maybe guessed 2mm.
https://www.corvetteforum.com/forums...post1575711652
Old Mar 20, 2018 | 05:20 PM
rblakeney's Avatar
rblakeney
Thanks for that. I searched and came up empty.
And here's a new shifter boot:
Old Mar 20, 2018 | 05:27 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
For some reason, I am remembering something odd....like 1.5mm? I'm fairly sure it was metric (and makes sense being made in Germany).
The presence of a picture implies the OP figured it out?
Old Mar 21, 2018 | 10:21 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
ZFDoc says it is a 0.077" on the following link. (that is very close to 2mm)
http://www.zfdoc.com/transmission.htm
Old Mar 21, 2018 | 10:32 AM
rblakeney's Avatar
rblakeney
Thanks, guys. I got it with the small Torx. It held enough for me to back the screw out and re-seat it tight enough. Hopefully I won't have to do this again for awhile.
Old Mar 21, 2018 | 10:48 AM
WVZR-1's Avatar
WVZR-1
That always humored me because it doesn't match either SAE or Metric
5/64 is .078125 and 2mm is .07874. I didn't recall and didn't feel up to checking. I might!! I thought I had a 'lift-ring' here in the house but I don't.
Old Mar 21, 2018 | 10:54 AM
rblakeney's Avatar
rblakeney
I oiled the ring lift rod and it's so much easier to work now.
I've owned this car less than a year and I find these little mysteries entertaining, if not frustrating. I learned to wrench on a 1976 Fiat Spyder and I could grab two screwdrivers and 10, 13, 17, and 19 mm wrenches and nearly take the whole thing apart. I don't understand the need for so many different fasteners on some cars. Seems it would be cheaper to make if there were fewer choices.
To Manual Shifter Pull Up Ring
