Recommended Brake Fluid
DOT5 has its own special formula and should never be mixed with any other spec.
Using a DOT4 fluid provides a higher boiling point so it will withstand higher heat. I use ATE TYP200 in both my Corvettes. It's a DOT4 fluid and will handle heat from autocross and track days. There are a number of good DOT3 fluids; Castrol LMA, Valvoline SynPower and even the Ford
HD Mortorsports DOT3 fluid will work fine.A DOT5 fluid should not be used as it's apparently not compatible with DOT3 or 4 fluid. But there are arguments as to whether or not this is true now for modern fluids.
If you haven't replaced the flex lines to the calipers, it would be a good time to do that when doing a fluid flush and refill
For a vehicle that is going to see Track use - I would not even think about NOT using DOT 4 fluid. I generally use ATE brake fluid on the stuff that is going to the track - which significantly exceeds the min DOT 4 specs, and is not hyper expensive.
If you are looking for cheaper DOT Fluid - Wal Mart typically has Prestone DOT 4 Brake Fluid for about $3.** a bottle.
There have been some posts about Valvoline DOT 4 not being very compatible with some seals - so you may want to do a search on that if you're planning to buy the Valvoline stuff.
Bottom line - while the DOT 4 fluid is slightly more expensive than the DOT 3 stuff - there is essentially no reason to use the DOT 3 over the DOT 4 stuff.
As for DOT 5 fluid - it's not hydroscopic - if you have a vintage car - that's driven hyper infrequently - maybe there is a reason to use it - but it's not compatible with the DOT 3 & DOT 4 stuff, and it's not as incompressible as the DOT 3 / DOT 4 stuff - so it's not recommended for ABS equipped cars.
If the rubber hoses are old, leave it alone till you change the hoses to either new OEM ones or SS braided ones.
DOT 5 is silicone based, and should not be mixed with conventional fluid.
Advantage of 5.1 is higher dry and wet boiling points than either DOT 3 or 4.
Type--Dry Boil Point--Wet Boil Point
DOT 3--205C/401F--140C/284F
DOT 4--230C/446F--155C/311F
DOT 5.1--270C/518F--190C/374F
5.1 is still hygroscopic, so it does still absorb moisture like DOT 3 and 4.
I've noticed no difference in braking and I don't track my cars. I just view the higher boiling points as insurance and safety margin.
My friends who do track their cars all use 5.1.
If you are changing, always a good idea to flush everything out. When I rebuilt brake system on my 86, I flushed the system first, then removed the calipers to replace the hoses and seals. Even though the fluid coming out of the bleeder was clear, the residue in the caliper from the old fluid/age was considerable.
https://www.amsoil.com/shop/by-produ...-EA?zo=1934716
But for a street car any good DOT3/4 fluid will be sufficient.
