Just pulled the ecu from the car and I’m not getting any grounded wire from the negative side of the injector wires - ecu at fault ??? Help needed guys
I guess if I were you, I would put it all together and use a test light connected to battery positive, that way you can properly test for ground with at least some amperage. Disconnect one of the effected injector connectors, and while its in the failed state, probe the ground side of the connector, if the light illuminates, then the wire must be grounded. It could be because the harness is shorted, or because the ecm is shorted internally. Disconnect the ecm and repeat, if the short is gone then consider replacing the ecm, if the short is still present then the harness must be rubbed through somewhere or otherwise shorted to ground.
That would be my vote. Not sure if there is a way to troubleshoot the ECM without replacing it but that's the only thing I can see causing this issue if the wiring is good.
OK done as said and light on negative side only when ecm is plugged in !
That's pretty conclusive in my book.
I guess substituting with a known good ecm is next. Which pretty much means replace the ecm and keep your fingers crossed.
yep got Ray sending me one next week, I’ll keep all fingers crossed when trying that one out
thanks for your help guys
Ben,
While you’re waiting for the ECM, disconnect all the injectors and ohm check each one. An injector with very low resistance could have caused the injector driver in your ECM to fail. If that’s the case, the new ECM would work for a while, then it could fail too. So a failed ECM could be the result of bad injectors. A cold ohm test of the injectors only tells part of the story though. If all your injectors ohm check good, connect the ECM I’m sending. If the car then runs, let it warm up, shut it down and retest all the injectors again. If they are still good, smile, it was just a bad ECM.
Of course you’ll want to change the oil to get rid of that fuel and you might also want to pull the plugs in case any fuel is still in the cylinders.
Yep oil changed and plugs are out, all the injectors are new AC Delco ones and haven’t even been run as yet, can’t start the car as it floods straight away.
Was testing it last night and with the ecm connected it’s grounding all 8 injectors at the same time, with ecm unplugged none are grounded, so my only thinking is the ecm has failed.
Are they of the newer design or NOS? IOW are they Multecs If so they belong with the garbage
Sounds good. Hopefully you’ll be running next week!
Thanks to all that that helped with this, turned out to be the ecm grounding all the fuel injectors at the same time, fitted a new ecm ( supplied by Ray ) and she fired right up better than it ever did before !!
