700r4 need help
Old Oct 16, 2002 | 12:05 AM
84 frok push rod's Avatar
84 frok push rod
Cruising
Default 700r4 need help
Can i put the tail from tranny on any 700r4? Or does it has to be for a corvette
Old Oct 16, 2002 | 12:23 AM
J Z06's Avatar
J Z06
Not too sure, but I'll bump this to the top for you.
Help this fella out guys..... :cheers:
Old Oct 16, 2002 | 12:57 AM
MrNuke's Avatar
MrNuke
Default Re: 700r4 need help (JD 90 383)
Well if you want your 3-4 WOT shift you need a 700R4 from a corvette. All the others in other cars like the f-bodies did not have the same valve body or whatever they call it.. AFAIK they are the same size though outside.
[Modified by MrNuke, 10:58 PM 10/15/2002]
Old Oct 16, 2002 | 12:00 PM
Vic'89's Avatar
Vic'89
Default Re: 700r4 need help (84 frok push rod)
The Vette tail housing and output shaft is smaller than the other 700R4's.
Vic
Old Oct 16, 2002 | 12:11 PM
Muffin's Avatar
Muffin
Default Re: 700r4 need help (Vic'89)
Tailstocks will interchange but mounts are different. You can put an F-Body 700-R4 in a Vette if you use a Vette tailstock.
To 700r4 need help
