Label on chip
Old Oct 16, 2002 | 09:27 AM
Blue88's Avatar
Blue88
Default Label on chip
I pulled the computer on my 88 and found a hand written label on the chip that read D01C-CAM. Digging through the records for the car I found some receipts for heads, cam, and timing chain/gears that the original owner had purchased when the car was fairly new. Does anyone know if these numbers mean anything? I am wanting to buy a performance chip but if this chip is programed for a different cam then I don't want to mess with it. Any chip programers know what it means? Thanks.
Old Oct 16, 2002 | 10:23 AM
ZylaRace's Avatar
ZylaRace
Default Re: Label on chip (Blue88)
That only means something to the guy who programmed the chip. If you have a scanner and lot of time, you can take a look at the data to see if it could be tuned better. If not, getting a new chip to work better than what you've got now, is a shot in the dark.
Old Oct 16, 2002 | 10:28 AM
chucks88's Avatar
chucks88
...........I found some receipts for heads, cam, and timing chain/gears that the original owner had purchased when the car was fairly new...............
:eek: :eek: :eek: Lucky Bastich
Old Oct 16, 2002 | 10:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Or you would have to scan the EPROM and compare with the stock '88 unit.
A chip usually isn't very beneficial to a MAF L98 unless some heavy mods have been done.
Anyway you have a custom chip; so to fine tune it now try base timing tweaks and AFPR adjustments.
Old Oct 16, 2002 | 11:07 AM
Blue88's Avatar
Blue88
Default Re: Label on chip (65Z01)
Thanks for the tips. I am still trying to locate the original owner to see exactly what he had done to the engine. Then I will try to locate someone who can do a custom burn for me.
To Label on chip
