96 zf6
Old Apr 5, 2018 | 07:07 PM
MikieG1971's Avatar
MikieG1971
Default 96 zf6
So my trans shifts fine. Not what id call butter but just fine. So i am wondering what shifter folks upgrade to?
This 1 to 4 shift thing. I have noticed that when the light is on, its nearly impossible to shift 1 to 2. Is this how this thing works?
i have noticed that ifi am abit more agressive with 1st, the 1 to 4 light does not come on and a 1 to 2 shift goes fine.
Old Apr 5, 2018 | 07:48 PM
s carter's Avatar
s carter
The 1 to 4 Sounds Pretty normal, as for Shifting like Butter if you don't have History of Car I would Start with a Change of your Transmission Oil it Did a World of Change in my car. I used Dealership Supplied oil I Had on the shelf in my ZF But I am sure there are some more Performance minded People out there that can offer other and Possibly more Modern Product Than the unopened & Remnant bottles I had.
Old Apr 5, 2018 | 08:01 PM
WVZR-1's Avatar
WVZR-1
Owners manual is 'free' - ZF shift is covered beginning at 2-24. Many by-pass CAGS - some don't just drive understanding it's there. Service the ZF? YES - frequently. Many fluids - that gets debated often. 17mm hex for fill and drain - remove FILL before any attempt to remove drain. If you need a new drain/fill plug. The local VW dealer can help with that. You need to consider a service of the clutch master and slave also. How to service gets debated also.
VW# for plug is WHT-001-937 and tell them to be sure 17mm hex. They have a newer 'spline' drive and may try to sell you that.
Manual:
https://my.chevrolet.com/content/dam...tte_owners.pdf
Old Apr 5, 2018 | 11:21 PM
gdl2165's Avatar
gdl2165
Along with all the fluids, it sounds like you want one of these:
https://www.zip-corvette.com/96-cags...-plug-kit.html
Old Apr 6, 2018 | 08:54 AM
MikieG1971's Avatar
MikieG1971
Just got the tranny overhauled so fluids are good. This disconnect howevet is golden!!!
can this plug be accessed from under the car?
Old Apr 6, 2018 | 09:14 AM
WVZR-1's Avatar
WVZR-1
Must be done from 'under car'!
Yes but with a '96 OBD2 make sure you buy one intended for the '96. Use of the incorrect will set DTC, also with just the jumper & reistor the light will still function. No CAGS but still the light. PCM requires modification to make the light go away.
I don't recall the 'resistance' requirement required but I'd think a DIY much less expensive than the 'BUY' once you add the shipping from anyone.
2.2KΩ 1/2 Watt from the 101 projects publication.
***There's 17 year old thread where one poster changed his mind it looks like 3 times LOL
I have 'The 101 Project' book and confirmed the read from there.
Old Apr 6, 2018 | 10:55 AM
MikieG1971's Avatar
MikieG1971
Thank you sir. I will order the part referrenced above. I also took your advice on the FSM. I bought the two book set for 96. They are red i think.
Old Apr 6, 2018 | 11:37 AM
s carter's Avatar
s carter
Just a quick question, did you check the clutch master level. My car gets a bit knotchy when shifting when low but not out
Old Apr 6, 2018 | 12:05 PM
MikieG1971's Avatar
MikieG1971
Had it flushed
To 96 zf6
