85 Replacement Window Regulators
Old Apr 10, 2018 | 01:15 PM
Wheels26's Avatar
Wheels26
Default 85 Replacement Window Regulators
On my 85 the original window regulators stopped working. I searched for replacement window regulators and selected the replacement window regulators from Corvette Central. I have had nothing but problems with them. They bent and the motor was so weak it was unable to move the glass up. I have been very frustrated with these window regulators with constant problems. I'm searching for another replacement window regulator that is strong, durable, reliable and at a reasonable price. Need the window regulator to work as well or better than the original equipment. Who manufactures a quality window regulator at a reasonable price?
Thank you.
Old Apr 10, 2018 | 01:39 PM
xrav22's Avatar
xrav22
What you want to do is the replacement of 85 ribbon type with newer scissor type.
Requires one hole drilled in the bottom of the door.
http://www.corvettemagazine.com/tech...grade-install/
Old Apr 10, 2018 | 06:02 PM
gerardvg's Avatar
gerardvg
Faster and more reliable, you wont regret it.
Old Apr 10, 2018 | 06:58 PM
Gibbles's Avatar
Gibbles
​​​​​​​i did the conversion, it's a huge improvement!!
Old Apr 11, 2018 | 03:15 AM
Wheels26's Avatar
Wheels26
Hi,
Thank you for responding.
Yes, I did get rid of the ribbon type with the newer scissor type. And yes, It required one hole to be drilled in the bottom of the door, but the cheap metal that the manufacture uses bends due to the glass weight or the new motor is too weak to move the glass up. It requires tapping on the motor to get the window to go up. I did hear about in my search that some people use a newer but used window regulator from a corvette instead of using an aftermarket brand new window regulator. Did you hear anything about that?
Ron
Old Apr 11, 2018 | 03:19 AM
Wheels26's Avatar
Wheels26
Thank you for your reply. You are right that the newer window regulator was faster than the original regulator. In my case, the reliability from Corvette Central replacement window regulators last maybe at most several months before it stops working. What manufactured replacement window regulator did you select? I'm checking out my options.
Ron
Old Apr 11, 2018 | 03:21 AM
Wheels26's Avatar
Wheels26
Thanks for your reply. Can I ask which replacement window regulator did you select? I want to check out that regulator.
Thanks,
Ron
Old Apr 11, 2018 | 07:38 AM
Gibbles's Avatar
Gibbles
Mine were oem, taken out of a later vette.
Old Apr 11, 2018 | 01:26 PM
383vett's Avatar
383vett
Ebay and Amazon both have oem AC Delco units. There are also aftermarket units available for less. Just depends how much you want to spend. I went with a Delco unit because I am keeping the car.
Old Apr 11, 2018 | 02:41 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Do those CC replacement regulators have "made in China" stamped on them? Is the problem bad regulators, or something went wrong with the installation?
The late model JY regulators in my '84 work great!! I have a good source, if you need help. PM me.
Old Apr 13, 2018 | 02:12 AM
Wheels26's Avatar
Wheels26
Since my posting, I found that I could purchase a later vette regulator from a corvette parts store tested and priced for $150.00. I believe that I'm going that way too.
Thank you for your response,
Ron
Old Apr 13, 2018 | 02:20 AM
Wheels26's Avatar
Wheels26
Nope, but I saw "made in North Korea". I have replaced two of them after going with CC's replacement regulators and need to replace another now.
I found a later regulator and it has been tested at a corvette parts store for $150.
Ron
Old Apr 13, 2018 | 02:26 AM
Wheels26's Avatar
Wheels26
Yes, I want to keep the car forever, too. I love the way the car handles and want to customize the hood to keep it cooler. I'm planning to go with later regulator that has been tested.
Ron
Old Apr 14, 2018 | 07:57 PM
zachaeous's Avatar
zachaeous
I replaced mine with OEM regulators from a later model car. I got two used units from a Corvette salvage yard for $139.00 for both plus shipping. Have not had any problems with either side and that were done in 2012.
To 85 Replacement Window Regulators
