Need help ... 96 LT4 SES light question
Of possible note, the initial episode occured about five miles after refuelling and was accompanied by a few seconds of very slight rough running. That one short moment aside, the engine has run flawlessly.
Any help would be appreciated. I hate to take it to the shop and pay someone to put a new MAF on it when that was the cure and I'd hate to buy one myself and find out it wasn't the problem. Cire96 :confused:
If the car is running ok now, then disconnect one side of the battery for a minute and reconnect. See if that eliminates your SES light.
This is a good first step and may work if your MAF is all cleaned up now.
If the codes return, post the running condition of the car and the codes you receive. I'd post the Helms troubleshooting pages but that'd be quite cumbersome as there are many.
[Modified by Dan Parker '96, 5:30 PM 10/16/2002]
Thanks. To clarify, the codes were cleared each time by disconnecting the battery in between each instance of the SES light coming back on. Last night, I decided to recheck everything and found that the rubber MAF boot was not correctly mated to the filter inlet on the bottom edge - such that there was a gap about a half inch wide and two inches long.
I reassembled it correctly and again disconnected the battery for five minutes. So far, so good with the light staying off during the ten mile drive to work today. I'll report again if that ends the problem.
Do you see any reasonable possibility that such a opening after the air filter and before the MAF could be the culpret? I can't, but electronics are my real weakness. Cire96
If it was oil then it may have burned itself off by now (and with the help of you cleaning it). And/or the MAF connector has started making a good connection.
For the 108 code (the MAP related one). The only far out guess I have (without resorting to electrical schematics) is that it may have shared the same 5.0volt reference circuit as the MAF and a poor MAF connection may have confused it. This is a huge guess as I'm rather disconnected from the whole situation :).
Hopefully this condition has remedied itself and you are good to go. Good luck.
The SES light is back on. Yesterday, after a full warm up, I disconnected the battery and the light did not reignite thereafter during a ten minute drive. But after the engine cooled for four hours, it immediately relit aftter start up. Does that tell you anything? Cire96
Eric
