Wire routing.
Old Oct 16, 2002 | 08:01 PM
blk90rdstr's Avatar
blk90rdstr
Default Wire routing.
Does someone here have the diagram for proper routing of the spark plug wires for an L98 (1990)and could you post it? Where can i buy the right clips and retainers for them too? :seeya
Old Oct 16, 2002 | 08:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Wire routing. (blk90rdstr)
I don't have the diagram but you can get the stock size retainers & separatgors from MAD or maybe Eckler's.
Old Oct 17, 2002 | 02:16 AM
vettl83's Avatar
vettl83
Default Re: Wire routing. (65Z01)
The Helms shop manuals have the diagrams, would be a handy manual to have. The clips are available from the Chevy dealer cheap. 84 CF 91 ZR-1
Old Oct 17, 2002 | 12:59 PM
VetBoy89's Avatar
VetBoy89
Here is a diagram for an '89, I think the '90 should be the same but I'm not sure.
:cheers:
Old Oct 17, 2002 | 03:07 PM
cash's90's Avatar
cash's90
Default Re: Wire routing. (VetBoy89)
I've got the 1990 manual which uses the same diagram that VetBoy89 provided from his 89 manual. The bad news is that our 1990s have the newer center screw valve covers while the picture shows the perimeter screw (pre-1990) valve covers. Since the wire retainers in the provided diagrams use the older perimeter screw locations for attachment, I do not know how the 1990 retainers originally looked.
Does someone have a 1991 manual and does it show the later valve cover configuration?
Old Oct 17, 2002 | 07:44 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Wire routing. (cash's90)
Routing in the manual is wrong, doesn't even show the EGR tube - which causes some interesting problems with the secondary wires.
BTW, center bolt valve covers started with the aluminum heads in late 86.
Old Oct 17, 2002 | 07:55 PM
WAY2FAST's Avatar
WAY2FAST
I don't see any diagram? Can you repost or send it to me too?
way2fast@charter.net
Thanks!
W2F
Old Oct 17, 2002 | 07:56 PM
65Z01's Avatar
65Z01
Actually the diagram (same one in my '88 GM Shop Manual) is very close though it shows perimiter bolt covers. The wire retainers just come up from below the valve covers with center bolts.
The other issue is that there are two clips under the EGR tube. The lower holds three wires; the upper holds the #2 plug wire. There are also heat protective sleeves over the wires where they pass under the EGR tube.
There was a note about routing the #5 & #7 wires back by the separator to minimize cross-talk but I can't find it either in my Shop Manual or in my Haynes. I don't think it's an issue if you're using spiral-wound wires.
Old Oct 17, 2002 | 08:13 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Wire routing. (WAY2FAST)
Thanks!
W2F
I didnt see it either. Thanks for the input. I dont necessarily have to have it exact but mine are just strectched across and wire tied to the hoses and stuff and was told it could be a problem later with rubbing or buring. I will check GM for the parts too and see if it gives me an idea how they go.
Old Oct 17, 2002 | 08:36 PM
65Z01's Avatar
65Z01
The diagram was there but apparently has been pulled.
To Wire routing.
