Engine and tranny swap(hood?)
Old Apr 19, 2018 | 01:13 PM
OleDog's Avatar
OleDog
Default Engine and tranny swap(hood?)
Leave hood on or take it off? I know their heavy, clumsy and probably a bitch to align correctly. Anyone pulled motor and trans with it on?
Old Apr 19, 2018 | 01:36 PM
WhiteC1's Avatar
WhiteC1
Yes, leave it on. I just pulled my engine a couple of weeks ago. Cherry picker in from the driver side with a screw type leveler. No big problem.
John
Old Apr 19, 2018 | 02:51 PM
OleDog's Avatar
OleDog
John
Thanks, apprieciate it
Old Apr 20, 2018 | 03:19 AM
gerardvg's Avatar
gerardvg
I pulled my hood off to remove the engine and transmission, was a lot easier than from the side with hood on.
(if you have a level concrete floor with enough room you can do it from the side with hood on).
As long as you scribe / mark the nut locations it will bolt straight back on in correct alignment. The nuts and washers leave a mark as well for easy alignment.
Old Apr 22, 2018 | 08:14 AM
Bagpype's Avatar
Bagpype
I too pulled my hood off to remove the engine. As gerardvg said, as long as you mark where it was lined up it will go back on with little fuss. I had two helpers to put it back on and one was 7 years old.
Old Apr 22, 2018 | 06:32 PM
RichS's Avatar
RichS
I always drop the transmission separately, then pull the motor with the hood on. Why screw with the hood if you don't have to!
To Engine and tranny swap(hood?)
