Snap Rings vs Heater Core
Old Apr 22, 2018 | 08:43 PM
SnorT91Man's Avatar
SnorT91Man
Default Snap Rings vs Heater Core
Okay, guys and gals, I'm getting down to the wire on my '91 rebuild; however, two of the toughest jobs have yet to be done. They are (1) remove the snap rings in the differential without a $30 pair of specialty pliers I'll only need one time, and (2) remove and replace the heater core, which I'll need some of the time. Here's where I presently stand--the differential is sitting on my workbench with the batwing removed, and inside the car the interior has been totally removed, including carpeting. Which project would you tackle first, the snap rings or the core? I'm curious if there's any justification for doing one before the other. Maintaining my sanity is a given!
SnorT91Man
Old Apr 22, 2018 | 09:43 PM
s carter's Avatar
s carter
SnorT91Man
I would go with the Heater Core, Get the most Frustrating thing out of the way. The rear you said it is sitting on the bench that you can deal with a cold drink next to you and work on in Peace as the weather gets warmer. As for the Snap Ring Pliers check and see if the local Parts store has a Loan a Tool, or just buy it you may say I won't need it but you may or a Friends might.
It's better to Have the right tool than to Loose your mind and Knuckles.
Old Apr 22, 2018 | 10:42 PM
jv9999's Avatar
jv9999
Can't speak to the heater core (knock on wood), but you'll need a good pair of snap ring pliers with short 90 degree tips for the diff. No getting around it. If not for removal, definitely for assembly.
To Snap Rings vs Heater Core
