Blower fan speed
Old Apr 23, 2018 | 04:50 PM
jbourff's Avatar
jbourff
6th Gear
Default Blower fan speed
My blower motor runs on high only. Replaced fan speed controller and ATC unit but still cannot adjust fan speed. Does not run when key is off or ac is off.
Old Apr 24, 2018 | 04:06 PM
Kevova's Avatar
Kevova
Which car? Do you have FSM ? Were both parts replaced for this condition? or something else? ATC? do you mean control head / display? Condition of blower power module connector?
Old Apr 24, 2018 | 04:24 PM
jbourff's Avatar
jbourff
6th Gear
1990 base conv. Do not know what FSM means. Both parts were replaced because the fan speed cannot be adjusted. Yes, the control head in the dash and the blower control under the hood near the blower motor. Connector was nice and clean.
Old Apr 24, 2018 | 06:23 PM
Kevova's Avatar
Kevova
Factory Service Manuals. Between the blower power module and the control head or dash control is the programmer. You need to check blower feed back circuit, between programmer and blower module. I not sure of programmer location.
Old Apr 24, 2018 | 08:56 PM
RalfKramden's Avatar
RalfKramden
When you say you replaced the fan speed controller, you mean the resistor pack on the blower motor?
If not, that's what your problem is.
Old Apr 25, 2018 | 08:46 AM
jbourff's Avatar
jbourff
6th Gear
Yes, that is what I replaced first.
Old Apr 25, 2018 | 08:54 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I believe this is the fan speed controller for C68 (climate control).
If you end up needing this part, I have one FOR SALE, HERE that works.
It mounts into the top of the air box, just down stream, or to the engine side of the AC evaporator.
Old Apr 25, 2018 | 09:33 AM
Kevova's Avatar
Kevova
There is a 5 amp fuse maybe labeled ac mod. On later models in dash on the 90 diagram I found location was underhood. The programmer controls the speed through the feed back circuit.
Old Apr 25, 2018 | 10:06 AM
jbourff's Avatar
jbourff
6th Gear
The picture you provided is what I replaced first. Then I replaced the control box in the dash and that did not fix it. There is a crusty looking fuse under the hood, right in front of the blower motor. It looks like a fusable link. That's probably the only thing that's been wrong all this time.
Old Apr 25, 2018 | 07:22 PM
jbourff's Avatar
jbourff
6th Gear
Corvettes are very expensive when you don't know what you are doing. I bought all those new parts and it turned out to be an 80 cent fuse. If you know anyone that wants to buy some good parts, let me know. haha.
Old Apr 25, 2018 | 07:29 PM
jbourff's Avatar
jbourff
6th Gear
Thank you for your help. You told me about that 5 amp fuse. I knew it was there but I did not know what it was for.
To Blower fan speed
