Optidoctor
Old May 5, 2018 | 08:24 AM
kittmaster's Avatar
kittmaster
Originally Posted by MatthewMiller
Leave it alone. If it ever craps out on you, THEN you should add ventilation. If you want to want to buy a good one (especially an Optidoctor one) to keep on the shelf as a contingency, that would make sense. But there is absolutely no credible reason to fix what isn't broken when the OE part is still working.
Right on the money.....this is one of those don't screw with it until it screws with you.
Old May 6, 2018 | 11:48 AM
Strick's Avatar
Strick
I picked up a new or almost new (never used) opti from a guy selling his C4. He had it on the self as a "just in case" option. How can I tell if it has the Mitsubishi sensor? I got it several years ago. (it's a 95) And I have it on the self for "just in case."
Old May 6, 2018 | 02:03 PM
Tripower delight's Avatar
Tripower delight
Originally Posted by Optidoctor
I am happy to share some of my Optispark experience. It is a nice side business that I am hoping to slowly grow. I believe the key is accumulating Mitsubishi sensors for the future.
1. I disassemble and clean everything. Remove corrosion. Replace the bearing. Re-assemble with Loctite and sealer. Add ventilation capability to the older Optispark base plate (assuming the owner wants to add ventilation). Install MSD's rotor, cap and center section. Test it and make a video to show that it works.
2. I am happy to add ventilation to any of the 1st generation Optispark's that I sell. I do it for no additional cost. I think it is really important! Some do not want to modify the design and prefer to keep it as is. I respect their thinking, but as some one who has taken apart countless cores, you want ventilation.
3. The key is keeping the sensor dry and clean. Sealing and ventilation determine the length of time that the sensor is going to see the disk clearly.
4. It's a high temperature sealing product that is used in the petroleum industry. I researched the sealer for a long time. I did not want to use a silicone based sealant.
5. Yes, I have done this several times. It is very easy to do. I charge $40 typically, less if there is an interesting story associated with the need to test it.
6. I'm a DIY guy and i'm all for helping people out, but this is a bad idea. You will probably only need to do this one or two times in your life. Getting all the parts together and finding a method to press in a bearing without losing the timing is just too much trouble.
7. I almost always replace the bearing. Occasionally, I will get one that is like new and I will re-use it. My LT-1 has an ACDelco unit in it that I refurbished. It was only 8 months old when it died, so I re-used the bearing.
8. I have never been asked. I think it would appeal to very few people. These few people would be excellent help if you ever find yourself shipwrecked on an uninhabited island.
So how does one get in touch with you? Do you sell them or do I send you mine and you rebuld it, and how much does it cost for your service? Thanks
Old May 7, 2018 | 07:18 AM
Whaleman's Avatar
Whaleman
https://www.ebay.com/sch/berrington1...p2047675.l2562
Old May 7, 2018 | 07:21 AM
Whaleman's Avatar
Whaleman
He sells rebuilt units or if you have 1 week he will rebuild yours. Not worth having yours rebuilt if it is aftermarket with a Chinese sensor.
Old May 7, 2018 | 07:25 AM
vette196's Avatar
vette196
You can contact him through the forum directly instead of eBay. I have his contact information if you need it
Old May 7, 2018 | 08:15 AM
Whaleman's Avatar
Whaleman
Yes, you can. I have his contact info also. I was just worried about getting him in trouble with Ebay. I sell stuff on Ebay but don't really know all the rules about doing direct sales. Maybe Brad can inform us what his policy is for direct sales. Dan
Old May 7, 2018 | 08:48 AM
vette196's Avatar
vette196
there is no policy. He is a private seller and he can do what he wants outside of eBay
Old May 7, 2018 | 09:04 AM
Whaleman's Avatar
Whaleman
Thank You for this clarification.
Old May 8, 2018 | 11:23 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
If you could send me his contact info I'd appreciate it.
Jporter@delcoalarm.com
610-541-6705
Old May 8, 2018 | 11:33 AM
vette196's Avatar
vette196
610-541-6705
Check your email...
I hope I never need another one, but Whaleman and I should get a great referral discount
Old May 8, 2018 | 12:47 PM
Whaleman's Avatar
Whaleman
Check your email...
I have a new rebuilt one with the Mistaubusi (sp) sensor and I had him rebuild my original 96 opti as a spare. I doubt I will ever wear out two of them. He does nice work. Dan
Old May 8, 2018 | 05:06 PM
  #33
1stVetteFinally's Avatar
1stVetteFinally
Anyone that needs to contact Brad (Optidoctor), you should just PM him here on corvetteforums. That's how I got in touch with him. I sent him a PM asking him to call me, and 5 minutes later, I was on the phone with him.
https://www.corvetteforum.com/forums...ptidoctor.html
Old Jul 15, 2018 | 06:38 PM
  #34
Tripower delight
Default opti trouble
This car is driving me crazy. its been three months dealing with this problem.
Do you have the optidoctor contact information Im going to get one from him thanks.
Old Jul 15, 2018 | 06:45 PM
  #35
vette196's Avatar
vette196
Optisparksolutions@gmail.com
His name is Brad
Old Jul 15, 2018 | 06:54 PM
  #36
Tripower delight
His name is Brad
Thanks friend for your quick reponse.
Old Jul 15, 2018 | 07:06 PM
  #37
GRKLGHTNG's Avatar
GRKLGHTNG
You too deserve to make a buck. I've looked over your price list, all of which are very reasonable. Keep on doing what you're doing, we appreciate it...unfortunately, there will always be people that want something for nothing. Then there are the rest of us, that understand the value in the service that you provide.
To Optidoctor
Old Jul 15, 2018 | 07:23 PM
  #38
vette196's Avatar
vette196
no problem, you can check out his eBay store... look up Optidoctor, it should give you an idea of his products/services
Old Jul 15, 2018 | 09:04 PM
  #39
Tripower delight
I tried emailing him the email don't go though. Does the ebay site give his phone #?
Old Jul 15, 2018 | 09:07 PM
  #40
vette196's Avatar
vette196
He is on here as well, search Optidoctor
