TPS cannot get high enough voltage
It did crank and run the next day after got it wet and showed a code 36. I cleared it before I put the new sensor on. Haven't rechecked the codes but it isn't showing check engine light.
i am driving the car now and seems to be running OK but does seem like it could idle little better.
Done a lot of reading and haven't found answer so come here to ask.
An easy way to verify if its the wiring or the TPS would be to take the TPS off the car, and 'bench test' it. With the TPS unplugged, take an Ohmmeter and measure from the signal port (middle I think) to ground. Open the TPS slowly, and observe resistance readings. Does the resistance go up evenly? Or does it jump around, stay still, go out of range?
The next test (which I think you've essentially done already) would be to put the TPS back on the car, plug it in, then measure voltage from signal to ground as you open the TPS slowly. Again, it should increase smoothly, and not jump around or stay still.
If the first test fails, then the TPS is likely toast. If it passes and the second fails, then I would suspect a bad ground or connection, possibly at the ECM, but possibly anywhere in the wiring harness.
i have a box full of maf, tps sensors, burnoff relays I have changed on this car in 18 years. Really been an ongoing problem. I'm thinking maybe the IAC may be a problem or bad maf. I really hate to be a parts changer like most shops do but I am stumped on this one. I've never not been able to get .45 volts on tps in those years but I caint.
I will take the sensor off and see if I have steady resistance when I have time. I'm not going to trust this car till I get this fixed and no codes glaring at me. Maybe I just need to trade up a few decades. Hope newer vetted don't have this problem. I've read a lot and code 36 is one of the biggest problems with these years. Seems everyone has found their culprit and all are different reasons. Wish I could find this one.
