Won't shift into reverse
Old Apr 29, 2018 | 10:51 PM
MJ6's Avatar
MJ6
Default Won't shift into reverse
I have a 1989 6 speed convertible, when I lift the ring to shift into reverse there is no tension to lift the rod so it can engage into reverse.
From searching the web I came up w/ the "Shift **** Reverse Lockout Trigger" as the potential problem.
I would appreciate anyone's help on how to repair the problem
Just today I was getting it ready for summer, and this happens. Thanks in advance.
Old Apr 30, 2018 | 07:38 AM
WVZR-1's Avatar
WVZR-1
It seems likely that the lift-ring has failed. In this link there's the GM part# and information that's likely useful.
https://www.corvetteforum.com/forums...post1594148025
Old Apr 30, 2018 | 05:00 PM
MJ6's Avatar
MJ6
Thank you very much, you saved me from a lot of research.
The diagram in the post you recommended showed me what needs to be done. Thanks again
To Won't shift into reverse
