1985 c4 horsepower??
Old May 6, 2018 | 04:24 PM
nick5263's Avatar
nick5263
Cruising
Default 1985 c4 horsepower??
I have an unmodded 1985 corvette with 160,000. I would like to get between 400 to 500 horsepower. My question is, what parts would I need and how much would it cost? Also, would it be worth it due to the high mileage of engine. Any input would be great, thanks.
Old May 6, 2018 | 05:51 PM
aklim's Avatar
aklim
IF it is auto, probably have to rebuild the trans to take the load and also a D44 rear end. Now we are talking 6 to 9 thousand on a good motor, couple grand for intakes and headers. Then you need someone to tune the thing so give or take $1000.
Worth is determined by YOU. IMO, it isn't worth it to me at this point. I'd have sold it and gotten something that uses an LS engine for easier modifications. OTOH, if you are absolutely in love with the car, it might make it easier to shell out that kind of money. IF you are like me and the car is a tool to get your jollies, perhaps not.
Old May 6, 2018 | 06:14 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
AKLIM is pretty much on target. You may be having a "bridge too far" moment.
So, rather than focus on a HP number, what do you want the car to accomplish or feel like? Remember HP is a dyno number, you can get a lot done with a lower HP number with a great combo.
350-375 is very doable with the L98 without breaking the bank and without major power train modifications.
Old May 7, 2018 | 02:02 PM
vader86's Avatar
vader86
Probably north of 10K to do everything.
You will need all the block work done, note you have 2 pc rear main seal from the factory and a hyd flat tappet cam, not a roller.
You must have new heads, yours are junk. You must have cam changed, and then a custom chip tune for the 85 which is different to tune than later cars.
You could reuse the factory TRW Forged pistons unless you have it bored out, which you will probably want to do.
You will have to get rid of the TPI intake to get close or beyond 500chp. You will want Superram, miniram, etc.
Labor, install, all that will add up with the machine work.
So whats the budget, whats the car intended to do for you, etc.?
Old May 7, 2018 | 07:11 PM
martymcfly's Avatar
martymcfly
Default a couple of options
https://www.summitracing.com/search/...t-engines-gm-3 or maybe https://www.jegs.com/i/ATK-Engines/0...92161&CATCI=pl
Old May 8, 2018 | 05:05 AM
Joe C's Avatar
Joe C
Originally Posted by vader86
Probably north of $10K to do everything.
Old May 8, 2018 | 01:35 PM
64Scout's Avatar
64Scout
For that much power I'd consider a turbo or supercharger. You're looking a 100% increase in power.
Or, an LS swap considering the time and money to get 400 hp from an l98.
Old May 8, 2018 | 05:03 PM
aklim's Avatar
aklim
You think the long block will support that? How about the trans and the rear end?
For his year, assuming he wants to spend the time and money, that might be viable. He'd have to get mounts and the ECM and harness and a fabricator to make it all work. Not to mention a tuner.
Old May 8, 2018 | 07:15 PM
aklim's Avatar
aklim
Originally Posted by ihatebarkingdogs
Buy a 500hp Mustang, Camaro or Challenger. Less money and more reliable.
I'd go with that.
To 1985 c4 horsepower??
