Random Tech
Old Oct 17, 2002 | 10:06 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Random Tech
I placed my order for an Random Tech CAT today....just awhile ago....
For '84 vette....how hard for me to install???? Or should I go to A muffler shop??????
What do you think?????
thanks
tony :confused:
Old Oct 17, 2002 | 11:16 PM
vader86's Avatar
vader86
Default Re: Random Tech (oldace84)
If you can get under the car, you dont need to go to a shop.
Old Oct 18, 2002 | 04:24 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe your '84 has a 4-bolt cat, bolts front & rear so should be easier than the later with a slip-fit up front.
You may also want to replace the hanger near the cat as the bolts could be rusted.
Also you will need some tubing to attach the AIR hose to the new cat; and likely have to cut that tube off the OEM cat.
Old Oct 18, 2002 | 11:26 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Make sure to soak any/all bolts with wd-40 (or some other good penetrating oil) 6-12 hrs prior to trying diassembly. Otherwise you'll risk snapping them off. I'd replace any studs/bolts etc. Otherwise the install should be a direct replacement of your factory cat.
To Random Tech
