1989 TPI stalls while cruising
Old May 11, 2018 | 09:04 AM
Anemeth1987's Avatar
Anemeth1987
2nd Gear
Default 1989 TPI stalls while cruising
Im working on a 1989 TPI MAF corvette and first thing in the morning it starts up shakes and dies the first time. then starts and runs fine. Through out the day it will stall randomly while driving. Stall as in SHUT OFF not sputter and quit. anyone have any dealings with this? is there a way to check the MAF sensor?
Old May 11, 2018 | 12:56 PM
TheBlaster9001's Avatar
TheBlaster9001
Bad TPS sensor can do that. Have you checked it out? I've seen a bad MAF, but they never killed the car, just made it run awful/sluggish. I had a bad connection on my TPS after swapping ECMs, and it would run for 2 seconds after key on, then die. You could keep it alive by staying on the gas. If you left off, it would die. When the car got warmed up, it would barely idle, and then eventually die. Fixed the connection and it ran good as ever.
So I would suggest checking the TPS, its pretty easy to do, and I can write up a guide if you would like.
Old May 11, 2018 | 01:26 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
In addition to the TPS, check your fuel pressure. It sounds like you may have some issues there. Pump, Filter, Pressure regulator.
Old May 11, 2018 | 04:44 PM
WW7's Avatar
WW7
Could be your "ignition control module" going bad.. If the car just shuts off like you turned off the key with no spitting or sputtering, but will start right back up again... Then it could be the ICM...WW
To 1989 TPI stalls while cruising
