Cam question !
Old Oct 18, 2002 | 10:53 AM
marlon88's Avatar
marlon88
Default Cam question !
As I am building a 396 in the near future in my 88 L-98 , I want to know that the ZZ9X camshaft from TPIS is any good for that setup ?? I am ordering the miniram setup next month and I tought that it will be tought full if I order the ZZ9X for my future setup !! what you think of this camshaft ?? does it work good in a 396 L-98 ??
thank you
Old Oct 18, 2002 | 01:25 PM
vader86's Avatar
vader86
Default Re: Cam question ! (marlon88)
It should go just fine with a 396.
Old Oct 18, 2002 | 04:24 PM
Raistlin's Avatar
Raistlin
what are the specs on the zz9x?
Old Oct 18, 2002 | 05:36 PM
vader86's Avatar
vader86
Default Re: Cam question ! (Raistlin)
290/290
239/239 @ .050"
.558/.558
112LSA
Old Oct 18, 2002 | 06:45 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Cam question ! (vader86)
I believe those are the specs for the ZZX.
For the ZZ9X I have:
287/290 dur.
225/240 @ .050
.525/.558 lift
lsa 116
These might be outdated though.
Old Oct 18, 2002 | 06:50 PM
vader86's Avatar
vader86
Default Re: Cam question ! (C4-Wolf)
I copied it directly from the TPiS catalog.
Old Oct 18, 2002 | 09:42 PM
Raistlin's Avatar
Raistlin
well, the 225I @ .50 would probably be a bit tame for a 396 miniram
the 239I @ .50 should be a screamer!
Old Oct 18, 2002 | 11:07 PM
marlon88's Avatar
marlon88
so the ZZX is more powerfull !!! wich cam you think I should order from TPIS (hydroulic cams) ? now I am thinking ZZX !! or should I wait and buy a better cam from somewhere else !!! what you suggest ??
[Modified by marlon88, 3:18 AM 10/19/2002]
Old Oct 19, 2002 | 12:23 AM
vader86's Avatar
vader86
You should find out the specs for the Cam before you go by what we say, call them and get the specs.
Old Oct 19, 2002 | 12:46 AM
Quick1's Avatar
Quick1
ZZ 9X specs are
287 290 advertised
225 240 @.050
.525 .540
112 lobe sep
ZZ X specs are
290 290 advertised
239 239 @ .050
.558 .558
all with 1.5 rockers
Call Bill at Lazer Cams, he is a super nice guy and he will tell you what you need! 1-901-795-6000 :cheers:
Old Oct 19, 2002 | 06:08 AM
gtsyellow's Avatar
gtsyellow
Default Re: Cam question ! (Quick1)
the zzx would just scream on a 396, it has my vote, make sure you get some good heads !!
Old Oct 19, 2002 | 11:50 AM
Raistlin's Avatar
Raistlin
Default Re: Cam question ! (gtsyellow)
the 396 has some cubes, i wouldn't look at any heads with less than 200cc intake ports, especially with the ZZX miniram combo
Old Oct 19, 2002 | 03:12 PM
C4-Wolf's Avatar
C4-Wolf
I think with the size of your motor you should go with something bigger than the zz9x also.
Old Oct 19, 2002 | 11:22 PM
marlon88's Avatar
marlon88
thank you all for the replys !!! hopefully next month I`m going to order the miniram and the ZZX camshaft !!! :cheers:
Old Oct 19, 2002 | 11:46 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
I hope there's no emissions on the island, the ZZ-X won't pass. It has a pretty radical idle.
I've ridden in an LT1 with heads and a ZZ-9X, and it pulled pretty nicely, accceptable idle too. The ZZX is a bit much for an everyday car, IMHO.
Old Oct 20, 2002 | 11:21 AM
marlon88's Avatar
marlon88
Default Re: Cam question ! (TrueBlue ChevyDude)
Here where I live we don`t have emissions !! I was just looking for a cam that in the future I will find it usefull in my engine project when I will built a 396 in my 88 ! as for now I am collecting the parts that I will need for this and when I am ready I will start it !! hopefully next month I will order the TPIS mini ram kit and the camshaft !! my vette is not my daily driver , It`s like a sunday car !! and for the idle and others it dont mater as long as I don`t have any vacum problms !!
thank you :cheers:
Old Oct 20, 2002 | 11:47 AM
Raistlin's Avatar
Raistlin
you'll also need a stout bottem end and long rods, you'll be shifting at 6500rpm+ :smash:
Old Oct 20, 2002 | 12:20 PM
Bruce's Avatar
Bruce
ZZX cam are very radical. Checkout tech review section. So far only one person on this forum has used this cam on 396ci LT1 ( Phil LT401). He says still streetable and made very good power. Also per Phil written up on the tech review, The cam ad say 239/239 @05. But when he degreed the cam its actually measured 242/242 @.05
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stgae II heads
[Modified by Bruce, 10:23 AM 10/20/2002]
Old Oct 20, 2002 | 03:05 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Cam question ! (Bruce)
I agree. You might want to look to another company as I have a ZZX cam sitting in my garage that spec'd in very poorly also.
To Cam question !
