How slow is "slowly"?
Old May 18, 2018 | 11:29 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Default How slow is "slowly"?
Checking my '87 EGR solenoid per FSM, first bit is making sure it's holding vacuum when activated.
FSM says "The vacuum may bleed off slowly, but this should not be considered a fault." My test, the solenoid went from -5psi to 0 in about seven seconds. Is that "slowly" or "fasty"? Ie, solenoid okay or need replaced?
Old May 18, 2018 | 04:57 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I would not consider that to be "slow".
The solenoid can't be that costly. Get a new one.
Old May 19, 2018 | 12:33 AM
kael's Avatar
kael
If I could get one tomorrow morning, that would not be costly.
Old May 24, 2018 | 09:30 AM
kael's Avatar
kael
UPDATE:
1) 7 seconds may be alright. The ECM may be activating by pulse, so vacuum will go down eventually. To confirm, bench test the solenoid. Hook up 12V to the correct leads and retest vacuum. My old one was fine with this test.
2) Do the same bench test for a new one. Mine from ZIP failed right away. Good thing I paid for 2 day air.
To How slow is "slowly"?
