468 SBC tall deck engine build
Old May 21, 2018 | 08:35 PM
tpi 421 vette's Avatar
tpi 421 vette
Default 468 SBC tall deck engine build
Hey Guys, I haven't posted any engine builds in a while. So I thought I would post a freshen up on mine. It's a 468 sbc (4.185X4.250). It uses a Dart iron eagle tall deck block. I reused my Lunati crank, and Crower billet rods. I got new custom JE pistons, their Hellfire rings. I had Strasburg machine do the machine work. And they went thru my AFR 245's, and freshened them up. I'm using the same cam, and same Miniram ported by Tony Mamo. Here's some pic's.
Old May 21, 2018 | 09:01 PM
tpi 421 vette
Here are some more
Old May 22, 2018 | 12:08 AM
Les's Avatar
Les
That has all the right stuff, put together by a guy who does it right. I can't wait to see and hear that bad boy make a pass!
By the way Jim, you still owe me a new set of rear tires for what you've done to the old ones on my avatar car with that little 396 you built for me.
Old May 22, 2018 | 09:34 AM
STEVEN13's Avatar
STEVEN13
Looks great Jim!
Good luck when you take it to the track.
Steve
Old May 22, 2018 | 11:23 AM
vader86's Avatar
vader86
ooooh engine ****
Old May 23, 2018 | 09:53 AM
tpi 421 vette
Here are a few more. I had my McLeod dual disc rebuilt, and while the headers were out, I had them recoated.
Old May 23, 2018 | 10:47 AM
dclafleur's Avatar
dclafleur
That's cool to see a miniram feeding that big of a motor.
Old May 23, 2018 | 11:16 AM
84 4+3's Avatar
84 4+3
Don't take this the wrong way but that is a beautiful engine.
Old May 23, 2018 | 12:20 PM
bjankuski's Avatar
bjankuski
Very nice!
Old May 23, 2018 | 12:29 PM
tpi 421 vette
Actually Tony Mamo did alot of epoxy work and porting on the miniram. It
flows over 400cfm
Old May 23, 2018 | 01:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Best thread in a long time. Love the pics. Thanks for posting, Jim!
Old May 23, 2018 | 02:11 PM
vader86's Avatar
vader86
I think you need over 500ci, and more cam.
Old May 23, 2018 | 02:13 PM
tpi 421 vette
Thanks, Guys. Here is a pic of it completely done.
Old May 23, 2018 | 02:18 PM
tpi 421 vette
Actually the final bore size with this block will put it at a 472
Old May 23, 2018 | 07:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Awesome, that is one big sbc who would guess!Pistons look sweet, good job Jim. Now you need more cyl head
Old May 24, 2018 | 10:55 AM
bjankuski's Avatar
bjankuski
So a 4.20 bore, how big can you get the bore?
Old May 24, 2018 | 11:16 AM
tpi 421 vette
4.200 is the biggest bore I have seen done with this block. With a 4.185 bore where I am at now, minimum wall thickness is .275.
To 468 SBC tall deck engine build
Old May 24, 2018 | 11:53 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I can't believe that you can go that big a bore on that block. That thing is wicked.
Old May 24, 2018 | 11:56 AM
bjankuski's Avatar
bjankuski
.275 seems like plenty of wall, I don't get worried until I get under .2.
Old May 24, 2018 | 12:11 PM
tpi 421 vette
Well maybe you could push the limits a bit on the bore, and end up at 4.250. That along with a 4.250 stroke would give you 482.33 CI.
