89 CA passenger window
If you roll the window down as far as it can go, does the motor sound like it is still going afterwards? That is, when you hold the switch down, do you hear the window motor still, or does the motor stop when the window stops?
Also, when you go to roll the window back up, does it move as soon as you hit the switch up, or can you hear to motor start going for a second or so, then the window goes up?
If the motor can keep going down when the window is still, the ribbon might be bad. If the window doesn't go up right after the switch is pressed up, the ribbon might be bad.
But if neither of those are the case, I would suspect that the window is just jammed on something.
