1989 a/c control issue
Old May 30, 2018 | 07:55 AM
unclet1's Avatar
unclet1
Default 1989 a/c control issue
My '89 has the C68 auto temp. control. The part that shows the temp. setting/outside temp. comes on and during driving it goes off. Everything
works just can't tell what the setting are. Anyone know of a fix before I send it off?
Old May 30, 2018 | 11:06 AM
TheBlaster9001's Avatar
TheBlaster9001
Sounds like a bad connection, either in the module, between the connector and the module, or somewhere in the wiring to the module.
Old Jun 1, 2018 | 01:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might try pulling the control module and cleaning the PCB contact fingers with an erasure.
Bit of a pita since you need loosen and pull back the console panel to access the two lower bolts but then the unit just pulls out so for an easy disconnect/reconnect.
If this doesn't do the trick it may be time for a rebuilt control unit, though there is a U-tube site vid on servicing the main PCB.
Old Jun 1, 2018 | 11:07 AM
R254's Avatar
R254
I had the same issue with mine and I was able to fix it by watching some of the Batee videos.
To 1989 a/c control issue
